730 gas, no power under acceleration/ backfiring
stringbean
07-17-2006 20:03:41
I have a 1960 730 gas. had not run for a year. i put a carb kit in it and flushed out the tank. it now runs but its seems to be lacking in power. When it is idling its ok and when going to accelarate it falls out then back fires. If you move it back to idle right away it comes back. I have tried adjusting the carb but no luck. I have tried hitting the choke and still nothing. It sounds as though it is missing. i firmly don"t think its something in the carb. I put new points, condenser, plugs in it with no help. there are no stuck valves, compression is good. Any ideas? would the governor out of adjustment cause this problem? thanks
stringbean
07-19-2006 20:03:52
 Timing in reply to stringbean, 07-17-2006 20:03:41
Thanks for the help.. It is the timing but i have some more questions? the number 1 cylinder is on the left side if sitting on seat? What rpm to time it at? and also, is the wire coming from the coil to the distributor supposed to be towards the governor of away? thanks
J.BENNETT
07-18-2006 13:22:15
 Re: 730 gas, no power under acceleration/ backfiri in reply to stringbean, 07-17-2006 20:03:41
JUST THOUGHT I WOULD PUT MY 2 CENTS IN. IT REALLY DOES SOUND LIKE THE DISTRIBUTOR/TIMING IS JUST THE SLIGHTEST BIT OUT OF WHACK. JUST WENT THROUGH THE SAME THING WITH MY 50'MT AFTER COUNTLESS HOURS OF RE CLEANING A FRESHLY REDONE CARB, CHECKING WIRES, PLUGS, AND MANY MORE THINGS, JUST TO HAVE THE DIST. JUST A FRACTION OUT TO FAR WITH THE POINTS. REALLY CHECK IT FOR RIGHT ON THE MONEY ACCURACY. MY MT DID THE SAME EXACT THING UNTIL I TWISTED THE DIST,AND DRIVE JUST ENOUGH TO BREAK THE POINTS. THEN ADJUST YOUR CARB. CHECK YOUR MANUAL FOR THE PROPER PROCEEDURE. I DIDN'T WANT TO MESS WITH MY GOVENOR EITHER. THANKFULLY WITH PATIENCE, IT WAS THE TIMING.
Jerry/MT
07-17-2006 22:36:46
Check your initial ignition timing and check your distributor advance to make sure that it is functioning.
Rick Goodman
07-17-2006 21:53:14
my dads 720 was doing that also, i richened the mixture and it quit backfiring and ran fine. a carb kit doesnt guarantee the passages are all cleaned out. if it has been sitting that could be the problem. good luck
JD hauler
07-17-2006 20:30:02
it sounds like there is still a problem with the distributor or the carb, I am leaning toward the ignition since you mention its backfiring some. see if anyone can let you try a unit off there tractor and see if that gets it going.
msb
07-17-2006 21:05:12
 Re: 730 gas, no power under acceleration/ backfiri in reply to JD hauler, 07-17-2006 20:30:02
Sounds like a centrifugal advance problem.
CPeter
07-18-2006 09:40:54
 Re: 730 gas, no power under acceleration/ backfiri in reply to msb, 07-17-2006 21:05:12
I think it is the carb. Check to see if you have good fuel flow. It sounds like it might be running lean. Do you have good flow from the tank?
CPeter
