JD 2020 Brake Problems
David Ingle
07-17-2006 17:05:21
I have a 1970 John Deere 2020. I recently lost pressure in both brake pedals. I tried bleeding brakes but no fluid came through the valves. I disconnected brake lines from master cylinder and plugged holes and still had no pressure in either brake pedal. The master cylinder is filling with hydraulic fluid when tractor is running as it should. Any ideas on what could be causing the problem? It seems odd that both brakes would go at the same time.
bak
07-24-2006 17:11:16
 Re: JD 2020 Brake Problems in reply to David Ingle, 07-17-2006 17:05:21
Just finished getting the brakes working on a JD 400 (same as a 2020). If you remove the brake assembly off of the side of the transmission you will find a ball bearing that is used to block the hole during manufacturing of the proportioning valve. We had this ball bearing come out and it allowed the fluid to drain back into the transmission. We taped this hole 5/16-18 and inserted a set screw with loc- tite. If you have a problem with the pedel going down slowly and the level of the fluid rising in the resivour check the condition of the popet valve and make sure that it is flat on the bottom.
ET
07-18-2006 06:34:32
You should pull the brake valve off and rebuild it. Pay attention to the inlet and outlet valves for each piston. Look at the equalizing valve, I suspect that is where the problem is. Its function is to lightly apply the second brake when you jam hard on just one brake. That takes some stress off the diffrential.
