3020 tin work
Scrib
07-17-2006 11:53:43
Does anybody know where I can find hood parts for a 3020? I was wondering if a remanufactured hood would be available especially the front end of the hood, which could be welded on, as mine is damaged due to front end loader.
Also need information where to buy remanufactured side screens. Eventually I'll be needing any number of resoration parts for JD.
Gerald J.
07-17-2006 15:23:06
 Re: 3020 tin work in reply to Scrib, 07-17-2006 11:53:43
shoup
www.shoupparts.com
And others.
Gerald J.
K.B.-826
07-17-2006 19:17:47
 Re: 3020 tin work in reply to Gerald J., 07-17-2006 15:23:06
I helped restore a 4020 this winter. We needed a hood, believe it or not, you can still buy them from Deere, for about $1200. I'd think that a 3020 hood would be about the same/slightly cheaper. We ended up finding a perfect hood in a salvage yard for around $500. They needed our old hood in exchange, which tells me they can straighten them out to resellable condition pretty easy. I had an old auto body guy look at the hood we had, and he thought it would be easy to fix, but money was no issue to the owner of the tractor. I'd say get an estimate from an auto body shop first, then check salvage yards.
G/MAN
07-17-2006 13:23:32
Grille screens are available new from Deere. $105 per, but at least they're still available, and the new ones are as good as the originals. As for the hood, you can also get a new blank hood from Deere (one that can be used for all fuel types and early and late tractors - the holes need to cut out), but they're high. I've never seen a patch piece for the nose. A good body man can do wonders with bent metal, but you might end up with a bill as high as the one for a new hood.
