4020 Steering problems
Tyler Kolbe
07-16-2006 21:11:54
I have a problem with a rebuilt steering control unit. I go through the bleeding steps and sometimes it works and sometimes it don't. It's horrible now. Sometimes it locks the brakes up. the line from the bottom of the control unit that goes to the top of the priority valve has vibration. If you push on the pedals it pulsates and steering is hard and the engine slows down a little. Lightly press the pedals when steering you can feel it pulsating. In other words it seems like brakes work if you don't do anything with the steering and vice versa. Any ideas. Kind of hard to explain.
HTR
07-17-2006 04:27:33
 Re: 4020 Steering problems in reply to Tyler Kolbe, 07-16-2006 21:11:54
There is no way anything in the steering valve could apply the brakes, unless there is something wrong in the brake valve. Try capping the pressure line off, that goes to the brake valve, and differential lock (if it has differential lock) and then try the steering. The brakes and differential lock are in the priority system, and returns to sump, all other functions return to the inlet side of the main pump. If this helps the problem, you probably have a bad differential lock valve, or a stuck brake plunger, and a blown Oring on a brake piston.
Bob
07-16-2006 21:30:04
Who rebuilt the steering valve, and what was the reason it was rebuilt? In other words, was it a Deere mechanic who's been around for a while, or did you exchange your original valve for a "rebuilt" unit from a junkyard?
It sounds like a massive high pressure leak in the steering valve that is overwhelming the return system that is shared between the steering and brakes.
Oh, yeah, you'd better start by checking the flow and pressure from the main pump, or was this done before condemning the steering valve in the first place?
