Hydraulics
Woody [NE]
07-16-2006 20:04:53
I have a Prince PTO pump running my F-11 Farmhand loader. The pump is about 8 years old without many hours on it. Most are winter hours for moving snow. The response on the lift cylinders has been getting pretty poor especially in warm weather. I changed the oil and filter this weekend and found chunks of something that look like packing or seal material.
I expect this if from the pump. Can it be rebuilt? What caused the pump to go bad, working it in very cold weather?
Thanks for your help. Not cold in Nebraska, last two days temp. was over 100.
Glen in TX
07-16-2006 20:50:35
 Re: Hydraulics in reply to Woody [NE], 07-16-2006 20:04:53
Yes, It could be rebuilt but you may have something wrong in the spool valves or obstructing flow there also and maybe nothing wrong with the pump. Check on parts or rebuilds with local industrial supply or hydraulic shop. Yep, the dog days of summer are here... groan. You got a place in Nebraska that sells all kinds of hydraulic goodies & new pumps too.
Roy Suomi
07-16-2006 20:46:57
Pumps usually don't have packing type material in them..What you're finding is probably cylinder packings gone south....Does the loader leak down after you are done with it?? Internal leakage shows up as a drifting down of the loader arms or bucket drifting down after the machine is shut off with loader in raised position..Does the loader have a suction screen in the reservoir?? This could be partially plugged and cause the loader to be slow.. Poor flow from a worn pump can cause slow functions too....A new pump can be purchased from Surplus Center .com
