Is it a 4020 or 4010
Ron Taylor
07-16-2006 19:08:59
I looked at JD a guy would sell.He said it is a 4010 but the #s don"t make sense if it is a 4010.The # on the plate on rear of diff.is sn7223r131427r.Would appreciate any help,also ballpark value.It"s been setting for several yrs.has factory cab good tires super nice sheet metal.It looks pretty clean. Thanks R.T
Bob
07-16-2006 21:35:42
 Re: Is it a 4020 or 4010 in reply to Ron Taylor, 07-16-2006 19:08:59
Here's a link:
95EB
07-16-2006 20:12:02
What you're seeing as a "7" as the first digit of the serial number is actually a "T". The "223R" section designates that it's a "4020" Diesel Standard with a Snycro-Range transmission. The last six digits after the first "R" are the actual serial number. Without looking it up, it should be a late 1966 or early 1967 model.
msb
07-16-2006 19:40:36
Quickest way to tell at a glance is to look at the hand grips.If they come out from under the cowling its a ten series.If the hand grip is just a U shape attached to the cowl,its a 20 series.Easy to see driving past at at 30 miles per hour.Another quick way;Flat PTO lever on the left side of cowling on a 10 series.Curved PTO lever on the right side of cowling on a 20 series.Exception would be a powershift transmission clutch disconnect lever on the left side.
Gerald J.
07-16-2006 19:40:22
Look at the PTO shaft. If it has a flange bolted to the internal shaft, its a 4010. If it has a large snap ring retaining the shaft its a 4020.
Gerald J.
Ron Taylor
07-16-2006 19:24:07
I don't have access to the new gen.ser.#s only what is on this site.So is the ser.# the first 4 digits before the R?I thought it was the 6 Digits after.thanks for info
JD9295
07-16-2006 19:13:59
isnt that number going to make it a 61-62 4010?
