3020 keeps flooding
Illinois Farmal
07-16-2006 16:58:32
I just acquired a 3020 gas about a month ago. This is my first green tractor and I"m not very familiar with their carbs. It seems to flood everytime I go to start it. Once I get it started it runs great and will restart if it hasn"t been shut down long. Is there a float that is sticking or some other adjustment needed? Thanks for all the great help.
Steve/IA
07-16-2006 20:17:32
 Re: 3020 keeps flooding in reply to Illinois Farmall, 07-16-2006 16:58:32
My 3010 floods something terrible if I try to start it with the throttle anything higher than idle speed. If I set it at idle and give her a little choke she pops right off every time. I have just got used to it.
Gerald J.
07-16-2006 19:47:01
I had multiple problems with my 4020 when it first arrived. It smoked like an IH diesel with a bigger cloud of black smoke after it had been idling a while.
I found these things:
1. The top of the Donaldson precleaner was pulled down, cutting air flow. It should be domed up. A little work with a small hammer fixed that.
2. The aircleaner element was dirty.
3. The choke wire wasn't anchored near the carburetor and wasn't opening the choke all the way.
4. There was junk in the hose between the air cleaner and the carburetor.
5. The float needle and seat were worn out. That was an important fix. The gas engine expert at the local JD store said he had all kinds of way to cut the gas consumption, but he wouldn't tell me any until I had replace that needle and seat.
Its certainly possible that the float could be sticking or could be not floating well.
After all the stuff I did (new copper wires, proper point gap and timing, new AC plugs, not Champion plugs because Champion plugs foul too easily and don't clean up afterwards), and the fuel things I cut fuel consumption from 400 gallons a year to 250 and I have to choke it for most warm and cold starts. I think I have it leaned enough.
Gerald J.
