HYD FOR A 1010 SERIES JD
Ted Goss
07-16-2006 10:58:54
On my earlier posting, I meant to say what type oil is used in the hyd system on a 1010 series JD? My three point hitch will not raise due to the system being low on Hyd fluid. thanks in advance for you help.
Glen in TX
07-16-2006 12:12:19
 Re: HYD FOR A 1010 SERIES JD in reply to Ted Goss, 07-16-2006 10:58:54
Use the JD oil and no worries then if other problems occur later you can bet it wasn't because of the oil. Be aware that some of the cheaper hyd. oils are not compatible with JD brakes linings and cause them to fail early and the material will plug the hyd. pump intake screen and/or filters. Your parts man isn't much of a sales person?
Osage
07-16-2006 11:20:49
Ted G:
I think I answered this already, however there is another item associated with the hydraulics that's equally important on this model tractor.
The only filter is a "screen" located in the end of the big(return)line as it comes out of the unit under the seat. First, you have to drain the system, then disconnect the big line at both ends to remove in order to get to the screen.
Hope this helps,
Osage
