Hot Re-Start Revisited (Glenn In Tx)
Green 51
07-16-2006 10:14:57
Thank you for the help with my hot start problem. Finally got around to the spark plugs, put in a set of Auto Lite 3116, solved the problem.
Now for you old timers out there, have a question about a 45 loader for a John Deere B. Need to know if the axle brackets have been reworked. Have 4 holes in plate that bolts to axle, this does not look like it was factory made. How many bolts should be used if factory made.
Thanks to those who answered my prevous posts and look forward to more expertise from all John Deere collectors.
Glen in TX
07-16-2006 12:17:44
 Re: Hot Re-Start Revisited (Glenn In Tx) in reply to Green 51, 07-16-2006 10:14:57
Glad you got it running again. On your axles there are only 3 bolts or studs right? JD 45 loader manual doesn't show the brackets well so I'm not sure but they did make brackets to mount the 45 on some Farmalls also. So could be brackets with a extra hole for that or universal one? I've never seen the 45 mounted on a Farmall though. Someone on here has recently been looking for Farmall brackets for the 45 loader. A 45 parts manual many show them well ?
