2040/milky hyd oil?
Tx Jim
07-16-2006 09:45:17
My daughter bought a 1981 2040 that had cracked shifter boots. The hyd oil was milky. She pulled plug and let it sit for 2 weeks. She installed new oil and filter,also inspected sump screen. She ran it 5 hrs and oil is milky again. What else can she do? We are fully aware of the affects "H2O" can have on the brakes! Thanks,Tx Jim
G/MAN
07-17-2006 07:46:51
 Re: 2040/milky hyd oil? in reply to Tx Jim, 07-16-2006 09:45:17
I agree that you'll probably have to change it again, and maybe a few times. Make sure the rockshaft is down when you change it, as the cylinder can hold a couple of quarts of contaminated oil pretty easily. And of course there will be some in other areas of the system that you won't get out without doing a flushing procedure. I wouldn't recommend using any sort of "cheap" hydraulic oil, as some of that junk will peel the paint of the inside of the castings, and your problems will just be beginning then. I'd use good hydraulic oil and possibly mix it 50/50 with diesel fuel, put the tractor on stands and run it in gear and cycle the hydraulics to flush it all out, and then drain it, change the filter, clean the sump screen and go back with a Deere filter and Hy-Gard, which is designed to tolerate a small amount of water. Also, some hydraulic fluids will cause more damage to brakes than a little water. 90% of the tractors we have come in with brake problems have Co-op hydraulic oil in them when we drain them.
JD9295
07-16-2006 19:10:28
yep check for more drains and go buy some cheap hyd fluid and be prepared to change it a few times. if water was in there it will be on the walls and every little crack, probably wouldnt hurt to overfill it a little and run it until warm then drain it until milk is gone then put in the good stuff
JDknut
07-16-2006 13:03:29
I assume you now have new shifter boots on there. Also, Bob's right on the mark, also check that you have all the oil drained. My 2350 MFWD has four plugs that have to be removed in order to get all the hydraulic/trans oil out, it is easy to miss one if you don't have the manual or know where they all are and it takes all of them out to get a complete drain. If you havent got all the old milky oil out, then whatever is left in there will just milk up the new oil.
Tx Jim
07-16-2006 14:31:14
 Re: 2040/milky hyd oil? in reply to JDknut, 07-16-2006 13:03:29
Yes, new shifter boots have been installed. I will investigate for more drain plugs. Thanks,Jim
Bob
07-16-2006 10:00:57
Change the oil again, and possibly again, after that.
