Adjusting Valves on a 1937 JD Model B
yoyos38
07-16-2006 06:07:08
How do you adjust the valves on a 1937 JD Model B?
Duane Larson
07-16-2006 08:53:25
 Re: Adjusting Valves on a 1937 JD Model B in reply to yoyos38, 07-16-2006 06:07:08
yoyos38,
Deere gives the method in their owners manual for that B. Pull the spark plugs. Rotate the flywheel until the flywheel side cylinder is coming up on compression (hold your thumb over the spark plug hole and you will feel more comression on the compression stroke than on the exhaust stroke). The magneto should impulse when the LHImpulse line on the flywheel lines up with the mark on the transmission case (flywheel mark is at 3:00 o'clock). Then continue to rotate the flywheel forward about 125 degrees past the impulse point (90 deg is when the LHImpulse mark is at the top, then continue less than 1/8 turn - as a check, the LH Exhaust Open mark should be about 1/8 turn below the mark on the transmission case). At that point all tappets will be loose. Loosen the tappet adjusting screw lock nuts, tighten the adjusting screws until the point when no movement can be felt in the tappet - they are just touching the valves, and then back the screw out 1/3 turn (two edges of the hex adjusting screw). This corresponds to 0.020", and accounts for any wear on the tappet face and looseness of the tappet on the shaft. Do this to all four tappets, tighten the lock nuts back, and you are good to go. These engines run cool enough that it does not matter whether the adjustment is done when the engine is hot or cold, but Deere never mentioned hot or cold so I assume they mean the engine is cold/cool.
