1975 410 hydraulics
ROY SAARI
07-16-2006 04:18:09
hydraulics for loader & backhoe are 60%. changed filters,hyd pump,reverser housing,cleaned suction screen,checked filter relief valves,changed filters & oil,pressure control valve had lock pin missing--replaced,reverser had blown gasket--replaced,changed all short suction hoses,it seems to me there is not enough oil coming from trans/charge pump as no pressure or oil coming from charge pressure port [bottom]on main hyd pump,but machine drives around very well and can spin the wheels which is steering me away from the trans pump,trying to keep the costs down as it is a backyard machine,any ideas out there----thanks a lot
Roy Suomi
07-16-2006 06:59:40
 Re: 1975 410 hydraulics in reply to ROY SAARI, 07-16-2006 04:18:09
One of the easiest fixes is the De-stroking solenoid on the Hydraulic pump..On the side of the front cover there are 2 small plugs..On the other side is the solenoid.. Take out the upper of the 2 plugs and install a 3000 psi gauge..The lower plug is charge pressure ..put a 200 psi gauge there..Read the pressure readings at about 1/2 throttle..If pressure readings are normal or near normal [ about 2300 psi-top , above 100 psi , lower]..If pressures are at spec , the next step is to go to your friendly local Deere dealer and purchase or borrow a "test plug" for the solenoid..Remove the solenoid and install the test plug and try the machine.You might have to work the bucket to unload the hydraulics to start the machine.Without the solenoid , the pump is trying to make pressure while cranking the engine.This plug bypasses the solenoid function.Let us know what you find , Many more fixes for lazy hydraulics on these machines..
ROY SAARI
07-17-2006 03:43:52
 Re: 1975 410 hydraulics in reply to Roy Suomi, 07-16-2006 06:59:40
The hyd pump on the machine does not have the de-stroking solenoid,just the plug.The first start the engine turns over well, after that I have to unload hyd using the steering.when I tested the the top plug on the pump I got 2500 lbs pressure, the bottom produced nothing.Thanks for advice.
ROY SAARI
07-18-2006 15:40:58
 Re: 1975 410 hydraulics in reply to ROY SAARI, 07-17-2006 03:43:52
Just to add to my last comment,pressure reading at the test port bottom of reverser valve was 90 lbs,think it should be 135lbs. tranny pump ?????
