G carb problems
JD G GUY
07-15-2006 19:42:39
OK here is the problem, earlier this spring i was using my 1950 G to pull 3 old telephone poles across the yard and it didnt have the power to do that. So I unhooked them and finished moving them with my unstyled B no problem. So I took the carb apart and sprayed it out with carb spray through all the little passages and cleaned everything up really nice and put it back together. still the same thing. no power, i have to run about half choke to get it to idle, and it spits and sputters.
I cleaned it again last week did the same thing, took all the little plugs out and sprayed everyhting out, set the float height because that was a little off, reassembled it and still the same thing.
I checked valve lash that was good, i tried seeing if it would idle with the load needle turned all the way in and it wont.
I am very stumped on this I have tried everything i can think of but being fairly new to these still, im sure there is something im doing wrong or missing
Thanks
and the fuel flow to the carb is as it should be
JD G GUY
07-16-2006 20:59:28
 Re: G carb problems in reply to JD G GUY, 07-15-2006 19:42:39
Thank you for helping with this, it is incredible the amount of knowledge shared here.
If i remove the brass nozzle to clean it how do I go about reinstalling it? would I just be able to tap it back in? I will also order the long drill bits this week, I would have figured that the carb spray would clean it but I suppose it rusts to the passage. thank you again and I will try these suggestions.
JD@Antique Acres
07-17-2006 08:23:08
 Re: G carb problems in reply to JD G GUY, 07-16-2006 20:59:28
To reinstall the nozzle just press it in. You may need to clean a little, they are made to slide in pretty easily and are held up by the nozzle spring. A common question is "does it need to be turned a certain way?" No it doesn't matter.
I also agree that you still have a blocked passage, they really do need to be drill out to be totally clean toi the correct size.
johns48b
07-16-2006 15:23:50
there is always a questions on carbs here it seems. i'm surprised that none of the guys haven't mentioned removing the rubber hose between the carb and air filter to see if you have an air flow restriction. probably carb like they say, but thats a simple test to make. i'm glad there are guys on here that know what they're talking about. i wonder to if your gas is frsh or not. i've been told that its only good for 30 days now before it starts going bad. i sure like keeping that fuel stabilizer in all my engines that don't get run much.
gtx1967jewison
07-16-2006 09:30:30
forget the throttle shaft! this is the single largest carb misconception out there. you can have extreme wear on shaft/bushings & cause no trouble. all the vac is on the side of shaft which is pulled tight against bushings so air does not enter here in any amount great enough to cause a change. also if this were the problem how did the thing run long enough to get that worn? I have n a worn here so bad the throttle plate gets stuck shut, you can move the shaft almost 2x it's width. tractor idles, pulls great. the trouble will likely be as stated in earlier posts- idle passages rusted shut. also you need to remove the brass nozzle in carb stem. you can only clean the passages with a drill bit, as stated. if you can't get the nozzle out tap it with a #12-24 tap deep as you can , grease the #12 bolt (hard to find) put washers on & tighten it into nozzle to pull it out. torch tip cleaners will usually clean the holes in it. good luck.
John T
07-16-2006 05:29:53
JD Guy, If she dont idle well I suspect its EITHER a vacuum leak such as around the throtle shaft bushings or a gasket OR ELSE the internal idle passages are clogged up which no amount of soaking or boiling out or spray cleaning will cure. The only way to really clean out all the idle circuit passages is to remove (usually requires heat first) each n every brass drill plug and use the correct No. 40 and No 53 long aircraft drill bits (from Roberts Carb Repair) to drill out n clean the idle passages. See
Link
If the idle circuits are alllll lll clean n free n drilled out but she still dont idle correct and some degree of choking helps, look for a vacuum leak. At idle spray carb cleaner or WD 40 or use an unlit propane torch all around the carb, especially the throttle shaft bushings (known place to wear n leak) and the carb to manifold junction and the manifolds base. If she speeds up or smoothes down at a location, you found a vacuum leak which over leans the fuel air mixture.
NOWWWWW W if she requires some choke to help her run better under a load and to pull, I suspect a low float level or theres not enough gas flowing into the carb bowl, but if thats all okay it could be the carbs main center vertical brass nozzle is clogged up. If you turn the gas on and oppen the carb bowls bottom drain cock plug a steady stream of gas 1/16 inch or so ought to flow continuous. If not look for restrictions in the carbs circular side inlet strainer or the needle n seat or else upstream at the sediment bowl or gas tanks outlet pipe. If thats all good then the carbs nozzle may be clogged up. To cure that you gotta use a make shift puller to remove/extract the center brass nozzle n clean alllll its lil side holes snd buff n clean it all up and reinstall n try it.
Let us all know, best wishes n God Bless
John T
P Browning
07-16-2006 04:45:20
JD G GUY -- Take a quick stroll over to the JD-H Restoration Site, and once there, click on CARBURETORS over at the left, Be patient to allow the piece to come up. It is a great read on JD single-barrell carbs.
Your carb has two paths for fuel-air mix into the engine, IDLE and LOAD. It sound like your LOAD path is obstructed in whole or in part.
What it appears - from your write up - is the tractor's engine isn't able to accelerate into a load. As you read the piece on carb's, observe the existance of a space in and around the fuel nozzle called an acceleration well. This well along with free flow of fuel through the nozzle is where LOAD fuel is drawn from wen a load is placed on the engine.
There is a simple no-wrench test called the LOAD & IDLE test (on the 7th page) that you can perform which will reveal to you whether or not either is blocked.
This should help greatly -- please write back to let us know what you find. (PatB)
Pappy
07-15-2006 22:56:33
Most likely, you have a clogged idle circuit in the carburetor. This can not be cleaned by spraying with cleaner. You will have to get the drill bits to clean the passages. Rust is most likely your problem. Check the archives, there has been volumes written about this problem.
Steve Crum
07-15-2006 20:32:09
Sounds like a vacuum leak somewhere. likely where the carb mounts or the manifold gasket is bad. Worst case scenarios are a cracked or burned thru manifold or possably it's jumped time. I would first start with the gaskets though.
