Matt VR -- Realize what is happening here. That carburetor has two channels for fuel-air mix going into the engine, IDLE & LOAD paths. It is the LOAD path that accelerates the engine. I take your commentary to mean the carb adjustments have been altered and you are looking for a reference point. Two things here: (1) Initial settings aren't critical for starting, so reset them as follows. BEFORE making any adjustments, however, please be careful when turning the two needles so that you do not run them down really hard onto their seats! You can quickly wrech the needle. With the engine not running, gently turn the IDLE needle CW (in) until it is seated. Then rotate it CCW (out) 1-1/2 turns. Also with the engine not running, gently turn the LOAD needle CW (in) until it is seated. Then rotate it CCW (out) one turn. (2) How does a JD carburetor work? How do you adjust one? How do you troubleshoot one? BEFORE you go out to your tractor to make the reference adjustments cited above, please read the piece I have posted on Carburetors. Go to the JD-H Restoration Site, and when you get there, look over on the left side -- click on CARBURETORS. That should help you a bunch. Enjoy! (PatB)
