jd 630 power steering
ken hamilton
07-15-2006 08:12:35
i have a john deere 630 with power steering and it has a ketch in it as you turn occassionally it sticks. any suggestions?
Glen in TX
07-15-2006 08:30:12
 Re: jd 630 power steering in reply to ken hamilton, 07-15-2006 08:12:35
You might try jacking up the front end and while engine is running loosen and tap the pedastal back and forth some to adjust it. Sometimes they bind there. You want the steering to stay centered and straight when you do that and if it turns to one side you need to move pedastal more other way and get it centered until you have even pressure to turn the steering back and forth left or right. Can also check wear on pedastal with it jacked up. If that doesn't work you probably have worn pins and sleeve in the valve assembly. They can be rebuilt with some patience and don't always need all new parts. If more rebuilding is needed a I&T shop manual or the JD SM2050 Power Steering service manual will help.
Bob
07-15-2006 08:16:39
You probably have loose or broken bolts in the lower part of the steering pedestal, that hold the moveable vane to the vertical shaft.
