fwd for 4020
john kahrhoff
07-14-2006 21:18:15
does anyone know if the rear wheel assist off of a jd 7700 combine will work on a 4020 that has powershift. thanks john
JD9295
07-16-2006 19:19:50
 Re: fwd for 4020 in reply to john kahrhoff, 07-14-2006 21:18:15
WHY? not being a smart@ss but like others said youll have more in it than its worth for help.
The 4040 HFWD sucked wind and the 4020 pump will be the same here
Glen in TX
07-15-2006 08:23:13
I'd agree that it would probably be more trouble than it's worth doing. You would need a larger capacity hydraulic pump I think to still have other good hydraulic functions while it is operating so it doesn't rob from functions too much like steering and brakes while a remote is in use also. Putting a larger pump in is no big deal and been done on many others with loaders before.
MSM
07-15-2006 01:50:04
It could be made to work,but I'm not sure it would be worth all the trouble. The factory fwa tractors had larger capacity hydraulic pumps to run the hyd. motors,plus numerous switches on the shifter,inching pedal,foward/reverse on the shift valve,plus all the wiring and hydraulic plumbing necessary to make it work.Even the factory setups were marginal at best,they might get you out of a soft spot,or give a little more traction,but if they were run all the time,the hydraulics tended to get hot,the wheel motors and valves leaked. Most of the fwa 4230's and 4440's around me have long since had the fwa removed and now run regular wide fronts
