1010 clutch replacement
Marty Z
07-13-2006 21:45:49
A Man called me today and wants me to replace the clutch in his 1010. I told him no, but now am thinking about it? I have rebuilt 5 pre 1939 JD's so I know I can do the job .Just wondered how hard it would be to rebuild his clutch. I guess I would have to split the tractor( no problem) but what would I have to take apart as far as the hood and electrical system? Is it a week end job or an "OH MY God" why did I start this?
He also asked what JD would charge for a clutch rebuild? I didn't know.
Thanks
Marty Z
johns48b
07-14-2006 15:56:53
 Re: 1010 clutch replacement in reply to Marty Z, 07-13-2006 21:45:49
half the fun on working on these old tractors, to me, is the fun of learning something new every time you fool with one of them. my dad use to say your not going to learn how any younger.
Ray
07-14-2006 15:39:48
If it has live pto there's a lot more involved,
you need specal tools to adjust the pto clutch.
If it's wore much the flywheel will probably need
to be turned.
Mike M
07-14-2006 11:07:56
I did one and it wasn't any different than a Ford or Ferguson to do. I got my parts from BMD.
Marty Z
07-14-2006 15:11:54
 Re: 1010 clutch replacement in reply to Mike M, 07-14-2006 11:07:56
OK thanks guys. I think I'm gonna try it. I did the clutch on the 8-N and that was not to bad.\
Thanks
Marty Z
Hayfarmer
07-14-2006 07:04:39
Time depends upon what you find. May be just the clutch plate or may be throw out carrier or...Doesn't take that long if you have a way to split tractor easily. As far as whet to take apart, just remove the hood and unhook every thing that goes between the two pieces. Have split my 430 a number of times. If you hang a blade or counterweight on the 3 point it will almost balance.
buickanddeere
07-14-2006 03:04:57
If some of the parts seem obsolete. Don't worry, JD used an ordinary Spicer brand clutch. Parts can be salvaged cheap off small Massey etc tractors of that era.
