4020 adding a turbo, pros and cons
Matt in PA
07-13-2006 18:20:46
I saw on ebay today a remaned M&W turbo kit for a 4020. What are the advantages and disadvantages to adding a turbo to the 4020? Can you get the additional horsepower to the ground in terms of traction and if so what effect does it have on the trans? Thanks for the input. Matt
Matt in Pa
07-16-2006 05:12:34
 Re: 4020 adding a turbo, pros and cons in reply to Matt in PA, 07-13-2006 18:20:46
Thanks for all you input! I don't think I'll put one on my 4020, its got plently of power for what I need, but one comes up with all types of ideas when cutting hay for 6 hrs. Thanks again for sharing your knowlegde, Matt
1961jd4010
07-14-2006 16:04:01
You can add a turbo as long as you don't get to crazy turning the fuel up. I would try to locate the M&W fan and larger oil pan. Also in our neighborhood there was a 4010 diesel that had propane injection that was a pretty healthy tractor but they ran a pyrometer and did not hot rod the tractor. Our old 4010 turned 128 on the dyno. It never had a turbo, just a cam out of a 6600 or 7700 combine and an injection pump out of a 6600. We put a clutch out of a 4320 also and really worked that tractor. But we tried to take excellent care of it also and never had any drivetrain or engine problems.
JDBert
07-14-2006 06:45:55
If you just put the turbo on and dont turn the pump up, you'll go from your current 95 horse or so to about 105-110. IF you still plow with it or do major field work like plowing with it, you'll be able to jump up one gear and it'll burn less fuel. If you get a pyrometer it should run about 900 most of the time and if you work the crap out of it you might see 1100 or a little more. Dont worry about the tranny it'll take it. The M&W turbo provides about 8 pounds of boost. I dont think the $1800 or so you spend on that turbo will quite get ya to a bigger horse, plus you KNOW what you got for a tractor now and you might just buy a whole new list of repair bills in a different tractor.
Rich in NY
07-13-2006 19:54:33
Put a turbo on my 4020 and turned up the pump. The PTO clutch slips at 150 HP. Have to be very very careful to only use the extra power only for reserve, it gets hot quick even with the 5 gallon oil pan and 7 blade fan. So I went out and bought a 5020.
jddriver
07-13-2006 19:54:27
We had a 140 hp 1968 4020 for 25 years and never had a moments trouble out of it Steve
Hayfarmer
07-13-2006 19:48:48
I think it will be ok if you don't too radical with it. Won't really help though unless you turn up the injector pump to match. JD built the 44 and 4630 with the 404 engine as used in the 4020 but it was built stronger, rods and crank vs the 4230 without turbo. The key is don't push too hard,may also shorten engine life. I think the transmission will hold up ok.
msb
07-14-2006 09:13:56
 Re: 4020 adding a turbo, pros and cons in reply to Hayfarmer, 07-13-2006 19:48:48
And don't forget the oil spray jets on the bottoms of the pistons the old naturally aspirated 404s didn't have.Plus a lot of other improvements made to the Deere turbo built engines.
G/MAN
07-14-2006 13:33:54
 Re: 4020 adding a turbo, pros and cons in reply to msb, 07-14-2006 09:13:56
Yes, adding a turbo and cranking up the fuel on a 4020 and pulling its guts out is asking for trouble. I've heard tell that the M&Wed 4020 belonging to one of our customers used to make 150 hp and they'd outwork 4430s with it, but I don't see how it ever held together. I put a clutch in it a few years back and dynoed it afterward, and it was making around 130.
msb
07-13-2006 19:25:09
Save your money and buy a bigger hoss like B&D says.Transmission can take it, the engine can't can't get rid of the extra heat the turbo creates. If you want to burn your engine up,just turn your injection pump to about 125 horsepower.
buickanddeere
07-13-2006 19:06:55
Cheaper, faster, easier, more reliable and easier to get a turbo 4020 built by Deere. They were called the 4320.
