2510 Injector Pump removal problem
Scott in SC
07-13-2006 17:13:59
I�ve got a 2510 that has an injector pump problem. The pump was rebuilt about 200 hrs ago, right before I bought it. Unfortunately, I�m not sure where the former owner had it done, or for that matter what was done. My problem now is that I can not get the pump drive out of the drive gear. The input shaft is keyed to the drive gear, and held in place by a nut. I�ve got the nut off, but the shaft is stuck in the gear, and there is not much room to try to tap on the loosened nut to drift the input shaft out. Anyone got any suggestions?
Scott in SC
07-14-2006 04:52:37
 Re: 2510 Injector Pump removal problem in reply to Scott in SC, 07-13-2006 17:13:59
Well I�ve got a parts book and operators manual, and thought I had a service manual for her, but didn�t. I�ve got to order one.
The pump came off the shaft and since I�d never seen one like that, I figured that was incorrect. The parts book shows an exploded diagram with the shaft in the pump.
I guess a small sheet of thin hard plastic would work for to hold the seal lips in place during the assembly process.
Glen, thanks much for the help. This nice little 2510 would have been much harder without your help in the past.
Thanks to all the others that have helped in the past also.
Scott
Glen in TX
07-14-2006 09:49:13
 Re: 2510 Injector Pump removal problem in reply to Scott in SC, 07-14-2006 04:52:37
I'm glad jdemaris mentioned the other pumps I forgot about. I take you have the DBG pump? The CDC and CBC pumps were never seen much around here on a 2510 for some reason. The SM2070 Service Manual for 2500 series tractors I have doesn't cover the CDC or CBC pumps or timing them for some reason? Maybe that is in the TM (technical manual) for 2520 ? The I&T JD-33 that covers 2510 & 2520 covers removal, install, & timing of the DBG, JDB, CDC and CBC pumps and shows the use of the timing pin.
Glen in TX
07-13-2006 18:58:07
Unless something else went bad and shaft is stuck in pump all you had to do was unbolt the pump and lines and slide it off the shaft. The shaft is a press fit in the gear and gear and shaft is removed as assembly with the timing cover off front if replacement is needed on it. Two lip seals are on the shaft that need to be replaced before sliding the pump back on with a seal tool holding the seal lips in place or you can make a tool for that. There is a timing pin on side of engine that fits into a timing hole in flywheel when removing the pump. All that is explained in a I&T JD-33 shop manual or a JD SM2070 service manual.
Ray
07-13-2006 18:11:07
I don't think it comes apart like that,the pump comes off toward the rear and the shaft and the timing gear stay in place.
jdemaris
07-13-2006 20:15:34
 Re: 2510 Injector Pump removal problem in reply to Ray, 07-13-2006 18:11:07
What pump do you have? 2510 came with either a CBC, DBG, or JDB. If you've got a CBC431-3AL or 16AL - then you are correct and the injection pump does NOT slide off the shaft. That only works with the DBG or JDB pumps. That pump should be held to the drive gear by one of two different methods. Early pumps - the CDCs, use three shear-bolts and a center-bolt and retainer that you take off from inside the timing cover - four bolts in total. The three shear-bolts are supposed to break if something goes wrong with the pump. The later C series - e.g. the CBC - has a tapered and keyed shaft that fits tight in the timing gear. The shaft has a cut-down section so it will break there in case of pump problems. If you have the tapered shaft with key - take the nut off, remove any washers, put the nut back on - but not tight. Put a large drift pin against it and rap it with a hammer -while at the same time backing up the gear with something - e.g. a small pry-bar, screwdriver, etc.
Glen in TX
07-14-2006 09:53:39
 Re: 2510 Injector Pump removal problem in reply to jdemaris, 07-13-2006 20:15:34
Thanks for mentioning the later pumps I forgot about. My 2510 SM2070 for 2500 series doesn't show those C series pumps? Did they cover those in a later manual or just the 2520 TM ? The I&T JD-33 I have covers all of them I believe but it is for 2510 & 2520.
jdemaris
07-14-2006 12:53:54
 Re: 2510 Injector Pump removal problem in reply to Glen in TX, 07-14-2006 09:53:39
I used to rebuild or repair injection pumps at several Deere dealerships - so I've got several lists. Deere's book is SM-2045 and it gives all pumps used on all tractors - ag. and industrial (within a certain year-range). 2510 ag. tractor is listed as having: CBC431-4AL (AT29732), CBC431-16AL (AT29732), DBGFC431-2DH(AR18026), DBGFC431-25AJ (AR70144), and JDB431AL2731 (AR69819). When the 2520 came out, it still sometimes used CBC pumps. 2020 used most of the exact same pumps as the 2510 as did the 450 crawler, the JD400 industrial, and the 202DE-01 880 Windrower.
Glen in TX
07-14-2006 16:05:30
 Re: 2510 Injector Pump removal problem in reply to jdemaris, 07-14-2006 12:53:54
Thanks for the SM number, I got it wrote down now. So what did you think about the C series pumps? I've been looking at a 2520 with that type pump and wondering if they were better or worse the DBG. Most everything we had used the DB pumps so that's what I'm familar with.
jdemaris
07-15-2006 07:02:16
 C pump stories in reply to Glen in TX, 07-14-2006 16:05:30
I think the CBC pumps were very good, but the earlier CDC pumps had problems. CDCs had various issues - but none that made the engine quit - more related to governor action and smoothness. There were several updates on the CDC until the CBC came out. But then . . . the problem was getting parts. Just about all parts became unavailable in the early 80s (maybe late 70s). So, Deere offered changeover kits to install the DB or JDB series pumps. In regard to the CDC pumps, they used shear-bolts inside the timing cover - which was not a great idea. When a pump siezed, the bolt-heads fell into the engine's timing case. I know where there are many machines from the 60s still running fine with their original CBC pumps. You are NEVER going to find a DB or JDB from the 60s or 70s still running that hasn't been part and gottten fixed. The plastic governor weight-retaining rings go bad over time - regardless of use and/or engine-hours. My neighbor is one example. He has a 350 crawler, and 2520 and 4020 ag. tractors - he bought all three new. His crawler has had two engine jobs, his 2520 three, and his 4020 just got it's fourth - and none of the machines have EVER had any pump work done (all are CBC pumps). There was a popular BS story going around in the 70s - I have no idea if there was any truth to it. The story claimed that two old ladies owned Roosamaster - they were heiresses I guess. And, for some reason - they would not allow ANY aftermarket or OEM reproduction parts to be made for the C series pumps and they were responsible for its demise. ???? Don't know what to say to that story - but I heard it many times, with slight variations, from Deere engineers and guys at Roosamaster pump-shops.
Glen in TX
07-15-2006 08:50:13
 Re: C pump stories in reply to jdemaris, 07-15-2006 07:02:16
Thanks for your time responding jdemaris. That's the story I was looking for. We once farmed with several new generation tractors too and they all had the DB or JDB pumps except the 6030. The 4020, 1970 year model I think?, we had must have came with the CDC pump? I just remember we had troubles with it and the dealer later replaced it with a another style pump and I never really understood why they had to replace it. I think you explained why as they probably couldn't get parts? We once had a good diesel shop nearby and only trouble I ever really had on ours was the throttle shafts leaking a lot after many hours on 2510 & 4320 so I took the pumps off and in for them to fix that a couple times over the years. They knew about the plastic retaining rings too and explained to me why the job would cost more and why they were replacing those also. Leaking throttle shafts or lines and boots were the only real problems we ever had with them and we always ran a good fuel conditioner too and later on ran the Standyne conditioner our rebuild shop recommended.
