730 John Deere PTO
farmhand
07-13-2006 15:51:20
I have a 59 JD 730 that came from the factory without a PTO unit. I was wondering what would be involved to add a PTO unit from a salvage tractor to it, so I guess my question is would there be any internal work that would have to be done other than sticking the unit in the back and bolting it up and hooking up the engagement pedal.
2cylinderlp
07-13-2006 18:53:07
 Re: 730 John Deere PTO in reply to farmhand, 07-13-2006 15:51:20
There are gears and bearings involved with this under the primary reduction cover. You would need those. There is the mechanism that lets you disengage the PTO driveline. You would need that. Then there are bevel gears, shafts and bearings in the bottom of the transmission which you would need. There are a couple splined shafts that go from the bevel gears to the rear housing. One more thing I don't know is if the main transmission case is machined to accept these parts on a tractor that was ordered without PTO. It would be a big job. But not much more work if you were doing a total restoration involving transmission rebuild, axle seal replacement, etc.
