2010 Highlift wiring questions???
DeereDiesel
07-13-2006 13:44:08
Hello, my name is Stephen and I live in east-central Missouri and my questions are about wiring a 1965 John Deere crawler/highlift. Some of you might have talked to me before about this but im sorry i still havent got it running for about 6 years know. The motor does turn over great and i belive that it will start once i get this wiring problem staightend out. It has a new coil, battery, points, condencer, plugs and wires. It is a 4 cylinder gas john deere engine. I want it wired so i could get it running, im not concerend about how it looks. I just want someone to tell what wires need to go where. Similar to wiring a Demolition Derby car from scratch. Ok, heres what i need to know, I would appreciate it if someone would tell what wires need to go where and how i should do this. Im a starting fresh with new wires and i have no idea where each wire needs to be hooked up to for this thing to have spark at the plugs. The old wires on the tractor are 75% missing so i would just like to start over. Whatever wires are on the tractor are in the wrong places. I just need to get this running. Im tired of seeing just sit there. Im 17 years old im on a mission to see this thing run. Thanks to everyone who posts back. I really appreciate it. God bless and thank you again!!!!! !-Stephen-
Mike 4020
07-14-2006 11:09:31
 Re: 2010 Highlift wiring questions??? in reply to DeereDiesel, 07-13-2006 13:44:08
Stephen,
Well to just get it running, really shouldn't be all that difficult. I am assuming that this is a 12v, negative ground system. You said that it turns over, so I am assuming that you have the starter & solenoid wired up. Then the only thing you are missing is power to the ignition system. Take 12 volts from the + battery and run it to the + side of the coil. (this is also the wire you will need to disconnect to get it to shut off)Wire the coil - to the post on the distributor. That should do it. You can verify power at the distributor by sticking a screwdriver in and open the points.. you should get some sparks. Next turn it over and very spark at the plugs. With spark there, then it should start(provided it's in time and all.)
Generally this wire that you run from the + 12v to the + coil would either come off of your ign switch or from the starter solenoid, and the starter solenoid could be powered off of the switch.
Hope this helps and Be careful.
Glen in TX
07-13-2006 19:09:30
How about buying some manuals for it ? Those would answer most of your questions. If you don't want to spend the money for a new wiring harness check with JD dealer service manager to see if they have service manual for 2010 crawler showing wiring diagram and could copy it for you. JD parts catalog for 2010 should show a harness also. http://jdparts.deere.com
Link
