JD 4300 quits running
T Fazio
07-13-2006 10:11:53
I need some help. My 4300 will just die while running. Then it will turn over, but not start. You let it sit for a while and it starts fine. Any suggestions????
F-I-T
07-13-2006 10:31:40
 Re: JD 4300 quits running in reply to T Fazio, 07-13-2006 10:11:53
Silt coated fuel filter? Had one a while ago that would let the silt settle to the bottom of the fuel sediment bowl and it would run until it stirred up and re-coated the filter. Also check the fuel return line back to the pump and check that the fuel tank cap if vented is working.
Frank
