Ignition timing 420 W
rurlndum
07-13-2006 06:53:38
What's the best way to set ignition timing? I used a timing light and set the spark to occur at the 'spark' line on the flywheel while running at fast idle. Is the book method of static timing better? Or is there a better way than either method?
Herny M
07-13-2006 14:47:26
 Re: Ignition timing 420 W in reply to rurlndum, 07-13-2006 06:53:38
rur
My book says that the timing light method is one of the two. The other is manual.
I think the timing light method takes all the guess work out of the equation.
Hayfarmer
07-13-2006 12:38:39
I prefer the timeing light method on my 430. While doing it check to see if the spark advances as you speed up. My distributor was stuck and wouldn't advance.
CPeter
07-13-2006 15:12:45
 Re: Ignition timing 420 W in reply to Hayfarmer, 07-13-2006 12:38:39
The timing light is the way to go, but remember that "fast idle" is 2025 =/- 25 rpm, not 800 rpm. That makes all the difference in the world. Also, as stated check to make sure that the advance mechanism works as you speed up the tractor. You are correct that the timing mark is the -SPARK-.
CPeter
