430W rear tire size
TD
07-13-2006 04:47:32
What is the correct standard rear tire size on a 430W?
buickanddeere
07-13-2006 19:11:04
 Re: 430W rear tire size in reply to TD, 07-13-2006 04:47:32
5:00-15 or 6:00-16. 13.6x28 or 11.2x34. A "W" chassis tractor will always be pointing uphill unless the 11.2x34's are used on the back. 5:00-15 are what is required to get a very slight, nose lower stance with the 11.2x34's.
8e3k0
07-13-2006 06:43:01
Rear tire size is 13.6 X 28 in 4 or 6 ply; the option was the 34 inch wheel but not too many. Fronts were 6.00 X 16 as most common.
chile2
07-13-2006 05:17:11
I believe 5.00x15 on the front 10x24 on the rear
