FH Round Spokes on Styled A
Mike Smith
07-13-2006 04:36:09
I have my Grandfather's old '43 A that I'm in the process of restoring. I know it wouldn't be correct but I am going to put a set of round spokes on it front and rear. To me these make any JD look much better than the solid wheels. Where can I find a set that will fit my splines? Are the front wheels pretty much the same regardless of year. I'm just trying to educate myself on what I need to know when it comes time to purchase a set. Tell me all the ins and outs on this subject.
Thanks,
Mike
Duane Larson
07-13-2006 20:15:15
 Re: FH Round Spokes on Styled A in reply to Mike Smith, 07-13-2006 04:36:09
Mike,
Do you want round spokes, or would flat spokes that were used on those tractors work? 15 spline round spokes may be hard to find - French & Hecht made the HC391F 15 spline cast-in hub wheel, and they also made the JD1270R 6.00S-36 and JD1271R 8.00T-36 round spoke wheels with bolt-in centers, however, the JD flat spoke bolt-in hub version of the 70R and 71R wheels are more common.
Round spoke fronts should not be a problem to find.
Mike Smith
07-14-2006 04:26:57
 Re: FH Round Spokes on Styled A in reply to Duane Larson, 07-13-2006 20:15:15
I always thought that any flat spoke was nothing but a cut off steel wheel. Were there actually flat spoke wheels that weren't steel and made for a rubber tire? I didn't know if it would be hard to find rounds or not but that's what I would prefer. I was at the Southeast Old Threshers Reunion in Denton,NC a couple weeks ago. There was a styled A and B there that had round spokes front and rear. I came around several times but never could find the owners with their tractors to talk to them about it. I'm learning.
Mike
Duane Larson
07-14-2006 06:16:42
 Re: FH Round Spokes on Styled A in reply to Mike Smith, 07-14-2006 04:26:57
Mike,
Shortly after introduction of the styled A's and B's, Deere introduced (4/1/39 Tractor Company Letter) their flat spoke rear wheels to complement the new styling of their tractors. However, they chose to "retain the same part number as the round spoke wheel" - a source of continuing confusion.
Anyway, no Model A tractors with 15 spline rear wheels (s/n > 488000) where shipped from the factory on flat spoke rears for rubber tires. The only flat spoke rears for 15 spline axles were the JD version of JD1270R and JD1271R, which used bolt-in hubs, and were first available sometime in 1945 as retrofits for steel wheels. Those wheels (discussed in previous note) are not too hard to find, and you would need the A2960R bolt in hubs and B1961R clamps.
Mike Smith
07-14-2006 10:53:50
 Re: FH Round Spokes on Styled A in reply to Duane Larson, 07-14-2006 06:16:42
I'd like to see a pic of a set of those wheels. What are my other options for putting rounds on it. Like I said before, I have seen rounds on styled A's just like mine. How are the doing it? Changing the rear axles perhaps?
Mike
Duane Larson
07-18-2006 20:34:17
 Re: FH Round Spokes on Styled A in reply to Mike Smith, 07-14-2006 10:53:50
Mike,
Pix of flat spoke wheels are shown in all the early '40's advertising, parts catalogs, etc. so should not be hard to find.
Other than the F&H round spoke wheels I mentioned earlier, I don't know of any with cast-in hubs that were made for your tractor. I haven't seen many tractors with them on, so I assume they are rather rare. The bolt-in hub F&H version of the JD1270 and JD1271 would be your best bet for locating round spokes in my opinion. They were made in the late '40's for retrofitting after steel and are not too hard to find. I would guess that is what you saw.
Of course, a 15-spline hub, any round spoke rear wheel, and a good machine shop can make many things happen - I've seen F-20 round spoke wheels on A's for example.
dab
07-13-2006 06:40:09
Detwiler. try this place they should know everything you need to know.
dab
07-13-2006 06:39:41
