620 Gas in Oil
Tom IA
07-13-2006 03:45:16
Changed oil in my 620 a couple weeks ago,after I finished,ran it for a while and put it away. 2 weeks later could smell gas. There was a puddle under the dip stick tube.Pulled the dipstick and it gushed like a hose. Doesn't seem like the carb is running over,could it possibly be the diaphram in the fuel shut-off. Thanks in advance for any help.
John T
07-13-2006 06:01:43
 Re: 620 Gas in Oil in reply to Tom IA, 07-13-2006 03:45:16
Tom, it couild well be the auto fuel shut off has leaky diaphrams. If you remove the lil oil line where it tees in and gas instead of oil runs out there, thats probably the problem. Replace the diaphrams and I replace the lil o ring/washer on top the lil vertical shut off plunger while in there.
John T
John VB
07-13-2006 05:27:57
Rebuild the fuel shutoff assembly and that should solve the problem. I did the same on my 620 when I got it.
Matt in PA
07-13-2006 05:00:04
I had this same problem in my 60 about 10 years ago. I am not sure the carb set up on the 620, but on the 60 there is a knob on top of the carb that shuts it off manually. If the fuel shut off that this knob is connected to if functioning properly, it will shut itself off when the engine shuts down. I think it works off of vacuum. Mine was bad and it put about 8 gallons in the crank case. Matt
