JD 70 water pip
DAve
12-04-1999 16:01:42
Need some help and advice. I am having trouble installing the lower pipe in the water pump housing. The pipe has already been cut and both pieces are connected w/hose. It went into the O-ring and housing on the head OK. On the other end, we've messed up three O-rings getting it in and it still leaks. We have more O-rings. Any suggestions??
Charles
12-04-1999 18:03:29
 Re: JD 70 water pip in reply to DAve, 12-04-1999 16:01:42
The most important things are: a smooth end on the pipe (use a brass wire wheel in your bench grinder), and lots of lubrication.
I had no trouble assembling the upper coolant pipe on my 50, although it did take a lot of pushing and twisting to get it in. Never leaked though. If it leaks you either have rust or pitting on the outside of the pipe, or you cut the o-ring with the edge (or dislodged it).
mark
12-06-1999 10:53:53
 Re: Re: JD 70 water pip in reply to Charles, 12-04-1999 18:03:29
use some vaseline or some kind of grease on the pipe and o-ring. should go together.
