differentual lubrication
Bill Warden
07-11-2006 21:06:33
I had a axel seal leaking on my 1952 model A John Deere. I went to the JD dealer to get the parts to make the repairs and the oil to refill the diff. with . The parts man told me to use regular hydralic oil in it. Ever since I put it back together both axel seals have leaked terribly. Even the one I didn't even touch. So I am wondering if he told me wrong about the oil? Maybe I should have 80/90 wt. in it instead hyd. oil. Anyone who could help me with this problem I sure would appreciate it.
ET
07-13-2006 07:16:14
 Re: differentual lubrication in reply to Bill Warden , 07-11-2006 21:06:33
You may have damaged the new seal when you installed it or when you shoved the axel in. The thin oil should not have leaked by good seals. It is hard enough to get at those seals that I always put both seals in even if only one was leaking. While modern hygard oil may lubricate the transmission just fine, it does nothing to deaden the noise of straight cut transmission gears.
machinery-man
07-12-2006 07:46:27
Oil seal repair is very difficult. The reason for oil seal damage generally is the bearing has gone bad and allowed axle to run on the metal part of bearing. without cleaning up the axle good and being extremely careful the new seal will be damaged. Also I run 140 about 2 quarts low and add about 3/4 cans of stp. The oil that was originaly used was just like molasses.
Kurt_JDB
07-12-2006 10:29:44
 Re: differentual lubrication in reply to machinery-man, 07-12-2006 07:46:27
Where do you get your 140? I have tried repeatedly around here to find a supply, and can't get people to even admit it exsists.
Kurt
Hayfarmer
07-12-2006 07:29:49
The problem seems to be that only a few of the parts guys(let alone service guys) have been around long enough to have worked around the old 2 cylinders. The old 2 cylinders didn't use hydraulic oil even in the hydraulics.
Mike M
07-12-2006 05:38:28
You did just one seal without doing the other while you were in there ???
Anyhow use gear lube the heavier the better whatever you can find.
bubba tubba 2
07-11-2006 21:26:05
Yea, 80/90 or 140 would be even better.What was that guy thinkin? er smokin?I'de take the oil back and spill it all over his parts counter.
van robinson
07-12-2006 01:25:15
 Re: differentual lubrication in reply to bubba tubba 2, 07-11-2006 21:26:05
I was asking the parts guy at my local JD dealer about 80/9o gear oil for my '40 B. He told me that what I needed was their Hygard hydraulic oil. I told him that my manual called for gear oil. He proceeded to argue with me and told me that Deere only specs Hygard for JD tractors. I quickly informed him that Hygard was not around when my tractor was made in Feb, 1940. He changed his tune quick, then told me what I wanted to know.
