JD 2750 Hyd. Problems
ol' guy
07-11-2006 19:28:06
I use the 2750 primarily with a 709 Rotary (3-point hitch)Cutter. It recently started a strange vibration/chatter when lifting or lowering the mower at "medium" engine speed. Obtaining the desired cutting height is difficult, and the height does not stay constant as you mow. New oil was put in a few months back, but the filter was not changed. It is full of oil, however. Any ideas what might be wrong??
JDknut
07-12-2006 14:02:16
 Re: JD 2750 Hyd. Problems in reply to ol' guy, 07-11-2006 19:28:06
If it happens at medium or higher engine speeds it could be the filter or the intake screen. Both should have been serviced when the oil was changed anyway, especially if it is not known when the filter was last changed. The screen can just be cleaned and then put back but, as with the filter, the oil has to be drained first. Also maybe there could be air in the system that has yet to be worked out. I'd check the easy stuff first before going to the more expensive possibilities.
