820 deisel
vopata
07-11-2006 19:25:09
i finally got this tractor started today,but i had to supply air pressure to the primary filter bleed screw hole to keep it running.i have replaced the spring and the check ball in the transfer pump and the gears look good so was wondering if any of u guys can tell me what my problem might be,i am pretty sure it is a problem with the transfer pump just dont know what.any suggestions?thanks rudy
vopata
07-12-2006 16:48:13
 Re: 820 deisel in reply to vopata, 07-11-2006 19:25:09
thanks guys i will give it another go.rudy
Mike M
07-12-2006 05:57:17
I'd suggest you put a gauge on it and check/adjust the pressures. I'd have to check the books for PSI specs. Don't have one handi here.
bubba tubba 2
07-11-2006 21:31:54
Purty sure ya ain't got all the air out of the system. I have seen the day when it took all day to get em bled out real good.Most likely ain't nothin wrong with the transfer pump.Just pull the plug, get a can under it to catch the fuel and sit and wait till that last little bubble comes out.It may take a long time.
