Flywheel play
Dean Lydey
07-11-2006 16:52:35
I'm doing a cosmetic restoration to a '40A. The mechanical corrections include a new manifold. I pulled the head in the process and decided to have a valve job including hardened seats. I wonder if I should proceed with a full engine rebuild. The tractor runs fine but I do have about 3/16" of play in the flywheel. It's a hand start.
Does this play warrant a rebuild down to the crank?
Thanks,
Dean
ARS
07-13-2006 08:35:25
 Re: Flywheel play in reply to Dean Lydey, 07-11-2006 16:52:35
i just adjusted the end play on my B this past weekend. the way i put the flywheel back on is: i greased the splines (some people say not to), then i got 2 scissor type car jacks (the type that normally come in the trunk of your car). i put one on the pulley side against the crank (with the pulley cover off) and expaned it against the tire. then i took the other one and put it against the opposite side tire and oped it so that it pushed the flywheel onto the crank. it worked really good and made it alot easier.
dab
07-13-2006 08:02:30
Make sure when you go to "push" your flywheel in you have someone on the other end holding a board on the clutch side. Remove the cover and put the board on the end of the crank. Other wise when you push on the flywheel the crank will move over and give you that play also.
ARS
07-12-2006 12:35:11
F-I-T, when you said dry the crank splines... do you mean you cant use any grease to slide the flywheel on?
F-I-T
07-12-2006 13:14:42
 Re: Flywheel play in reply to ARS, 07-12-2006 12:35:11
Nope. No lube at all. Any oil will just promote the joint from moving.
Frank
F-I-T
07-11-2006 17:23:50
Dean:
Do you mean rotational play (rock) or end play? 3/16" endplay is extremely excessive, but might be easily adjusted by repositioning the flywheel on clean and dry splines and re-tightening the flywheel bolts. Replace the bolts if they seem stretched. My old JD mechanic mentor always replaced them because he said it was pretty cheap decision point. .005-.010" is pretty much the standard on endplay tolerance.
Hardened seats are nice in that head, but it's probably overkill unless you intend to pull it very, very hard. If you are retaining the old all-fuel, low-compression pistons, you probably will never see exhaust temps that would require hardened seats. Just a thought.
If you have 3/16" rotational play, you are seeing the accumulated wrist pin and rod clearance. I'd have to do the math, but that off the top of my head does not seem all that high given the diameter of the flywheel. If it does not knock or use oil, I'd be inclined to leave it alone, but ultimately you'll have to be the judge.
Frank
Dean Lydey
07-11-2006 18:28:49
 Re: Flywheel play in reply to F-I-T, 07-11-2006 17:23:50
Ouch! I do mean endplay. When you say replace the flywheel bolts, are you suggesting that the flywheel is moving on the spline that is visible looking at the flywheel? This isn't the case. The flywheel is secure on the spline. I believe there is some kind of bearing wear internally on the crank. The 3/16" may be an exageration but it is certainly greater than .005 to .010".
F-I-T
07-11-2006 19:34:56
 Re: Flywheel play in reply to Dean Lydey, 07-11-2006 18:28:49
Dean:
It might have just been installed with too much endplay to start with. On replacing the bolts, it's my experience that, after several torquing sessions over the years, those bolts can stretch and a fresh pair is step towards making that joint a bit more stable. It's not uncommon for a flywheel to creep over time, but as I say, some folks don't set them to the minimum endplay tolerance from the get go.
Frank
