Hydraulic connection fittings for 3020
Illinois Farmal
07-11-2006 16:14:58
Do the remote hydraulic connections of a 3020 require John Deere male fittings on the hose ends or will generic fittings such as Pioneer fit. The hydraulic connection on my 3020 have the little levers which turn 90 degrees when connecting. Thanks in advance.
Nylon
07-11-2006 19:02:07
 Re: Hydraulic connection fittings for 3020 in reply to Illinois Farmall, 07-11-2006 16:14:58
Try one that you know what it is for sure before you buy them. Most likely they are the old JD style. There is also a new JD style. Think they are ISO something. I use the JD to pioneer adaptors but again there are a couple of different styles/sizes.. I found one that fit what I had and brought it in to see what it would fit in the store. Then I knew what I had and what I needed.
John
JMS/MN
07-11-2006 17:16:32
Unless the basket has been changed, you need the male JD tip. You can tell by looking at it- the JD end is tapered, the Pioneer is straight. You can buy adapters for $10-15.
Illinois Farmall
07-11-2006 19:22:19
 Re: Hydraulic connection fittings for 3020 in reply to JMS/MN, 07-11-2006 17:16:32
They are the original baskets and it is a 1966 model 3020. Are the original style male ends still available or are adapters the only option? Thanks.
JMS/MN
07-11-2006 21:45:58
 Re: Hydraulic connection fittings for 3020 in reply to Illinois Farmall, 07-11-2006 19:22:19
Original ends are still available at JD dealers, NPT or O-ring style. Both fit the JD coupler, but you need an adapter to go to a Pioneer coupler. Same thing when you have an IH coupler and a Pioneer hose end.
