Grille Screens
Wes Storm
07-11-2006 16:01:22
I"m needing to rebuild the grills for a 1950 G. Where is the best place to buy replacement grille screens? I have seen several different companys selling them. If you have any experence please let me know. i want it to look like the origonals.
Thanks
Wes
Billy C.
07-12-2006 06:53:21
 Re: Grille Screens in reply to Wes Storm, 07-11-2006 16:01:22
Richard Duane
410-643-2899
311 Congrssional Dr.
Stevensville, MD. 21666
I got new screens for my H from him and they look and fit real well.
Wes Storm
07-12-2006 16:47:20
 Re: Grille Screens in reply to Billy C., 07-12-2006 06:53:21
Thanks for info.
Wes
jdhbag
07-11-2006 18:13:59
It all depends on how much you want to spend. I buy all of mine from Richard Duane. They are expensive but they are accurate, accurate, the best that i have seen, as good as the factory and maybe even better.
Wes Storm
07-11-2006 19:51:12
 Re: Grille Screens in reply to jdhbag, 07-11-2006 18:13:59
Do you have Richards tel # and address?
Thanks
Wes
Wes Storm
07-11-2006 19:51:05
Thanks
Wes
B-maniac
07-11-2006 17:26:55
I just replaced the screens on a '50 "B".I believe it is the same screen,just larger size that you need. You can buy the "perfect" pre-formed screens that have the dividers in them,(they are hid behind the grill bars so you will never see them anyway)for abt. $40 ea. Or you can do like I do and buy it in sheet stock from the same vendors for less than half the price and form it yourself (it's pretty easy) It won't have the wide dividers in it but you will never see them when installed.I'm sure the "correct police" will have their flashlites out and show through the grill from the opposite side to see what you have though.If that's an issue then pay the big money.I believe most comes from the same manufacturer and is all good quallity.Most reproduction parts suppliers won't carry it if it isn't up to snuff. Check on the net or Green Magazine. You can either spot weld it in place or what I do is Quik JB Weld it in place.I do this because I like to paint the inside of the grill and paint both sides of the screen and put the two together without burning anything and giving rust a place to grow. It all depends on your do-it-yourself abilities as to which to buy and how you do it . And your patience!! Good luck on the "G".
Mike M
07-12-2006 05:51:32
 Re: Grille Screens in reply to B-maniac, 07-11-2006 17:26:55
Have you ran those long with that JB weld and does it hold up over time and vibration ?
It may just be what I need to fix the screens in my tractors I did way back before screen was available. I never wanted to repaint the whole grille as welding would burn my paint off.
B-maniac
07-13-2006 16:29:17
 Re: Grille Screens in reply to Mike M, 07-12-2006 05:51:32
Mike; havn't heard of any problems yet.Some have been out there a few years. What I can't tell you is if they are working those tractors or just playing around but I believe they run them quite a bit and no complaints yet. The B I just did for myself and plan to keep will be a better test. I would trust it over some of the marginal spot welds they came with and even they lasted quite a few years.Tech. has come a long way. Can you believe connecting rods made of powdered metal composites.They are used in applications you wouldn't believe. On a grill that is painted and just needs screens,I would use it in a minute,especially before welding and re-painting!
