JD 158 LOADER
web
07-11-2006 08:44:11
Has anyone out there changed the packing and o-rings in both lift and tilt cylinders. Is it a big job? Does the ends of cylinders unscrew?
Mike M
07-12-2006 07:15:05
 Re: JD 158 LOADER in reply to web, 07-11-2006 08:44:11
Should add a word of CAUTION !!! Air pressure applied in those cylinders to free them is a NO NO ! Best to pull them apart.
web
07-18-2006 06:47:46
 Re: JD 158 LOADER in reply to Mike M, 07-12-2006 07:15:05
Did my bucket cylinder this past weekend. Found that a slide hammer works for removing the rods from the cylinder. It was as each of you suggested; very messy with oil, and somewhat difficult installing the rods after the new packing was installed.
Nylon
07-11-2006 19:10:37
I did my 148 loader bucket and lift cylinders. It can be a bit of a bugger. 2 guys is a plus. Really toughest part is getting those dingbat designed snap rings out. The other trick spot is if some one really torqued the end nut holding the packings. You dont want to score up the cylinder trying to unscrew the nut. Big air impact can help. Think that nut is 1 1/8 or 1 1/4 on 148 may be a bit bigger on 158. Once packings are on I drove assembly into bore by lifting and dropping on a 2x6 on concrete floor. Other problem is getting them out of the bore. The can be pulled out or hooked up to hydraulics and forced out. I am a neat greak but you may as well plan on oil being everywhere. Those cylinders also hold alos of oil so have bucket ready and outsmart them :]
John
web
07-12-2006 06:46:23
 Re: JD 158 LOADER in reply to Nylon, 07-11-2006 19:10:37
Nylon,thanks for the tips!
web
07-11-2006 18:03:53
Mike, thanks for the reply. My cylinders have a snap ring at the end, didn't know if you unscrewed the end after snap ring removal. Sounds like there may be an internal snap ring also. Thanks!
Mike M
07-11-2006 12:36:28
I did our bucket cylinders awhile back. I don't think it was too bad ? I think ours may have a snap ring or a retaining ring of some sorts you take off or out ? then shove the end down in a little and remove another retainer then pull the end out. The inside packing should be held together with a large nut and real tight.
I need to do the lift cylinders as one has an intermitant leak.
