Belt Pulley
JD 41 B
07-11-2006 08:03:07
My 1941 B has some play in the belt pulley. When I say play I mean that if you grab both sides of it, it will move slightly. What causes this and how difficult is it to fix?
ARS
07-12-2006 12:43:55
 Re: Belt Pulley in reply to JD 41 B, 07-11-2006 08:03:07
I had a 47 b that was terribly worn from that front bearing. it was so bad, it wore a groove in the crank. i put a new bearing in it and it didnt help a bit. hopefully yours isnt that bad. i would look at that front bearing first.
Mike M
07-11-2006 12:42:49
You say slightly ? Is this with the clutch disengaged ? If it is indeed slight don't worry about it as it needs play to work right if it was too tight it would lock up tight on the shaft. They have to be real bad before a new bushing helps them as JD presizes them and makes them too big inside. You had that off before if I remember right ? how did the outer bearing look and did you repack it with grease ? if it wasn't all rusted up and pitted real bad it should be fine. If you have the clutch locked in tight and have play then it must be the main bearings need tightened up or replaced.
