420 re-wiring, made a mistake
JD 4020 3020 62
07-10-2006 19:49:54
I am re-wiring me 1956 420w, as part of a restoration project. I seemed to have eithor forgot to label, or lost the tape that labled one of the wires. It is one of the wires that hooks to the fuse holder. I know one of them goes to the regulator, and I think the other end goes to the switch. Just I must have the wrong post on the switch(I guessed and put it on the same post as the wire that runs to the coil). The tractor starts and runs, all the lights work right, but it will not shut off when the switch is turned off. I don't have a diagram or repair manual handy, so I figured this was the quickest way to fix my ooops! Thanks
JD 4020 3020 620 420
07-11-2006 11:09:10
 Re: 420 re-wiring, made a mistake in reply to JD 4020 3020 620 420, 07-10-2006 19:49:54
Thanks! Simple mistake to make when its been apart for 2 months!
Johnnyputt
07-11-2006 04:23:28
third party image
This will help you!
rurlndum
07-10-2006 20:39:53
The wire going to the coil is on the wrong terminal and is hot all the time. Look at the back of your switch for a terminal stamped ign and put the coil feed there.
