3020 running good again
Illinois Farmal
07-10-2006 19:34:29
I contacted the dealer I traded with and he came out today to check my 3020. Apparently there was a set screw/needle that was missing from the carb causing it to run like crap. Fired it up when I got home and it ran 100% better. Now if I can just find where the power steering pump is leaking from. It doesn"t leak all the time but when it does it leaks alot and of course the oil is everywhere making it hard to see where it"s coming from. I"ve eliminated the little plastic return line. Any other ideas? Thanks to everyone.
Mike@Minn.
07-11-2006 15:26:00
 Re: 3020 running good again in reply to Illinois Farmall, 07-10-2006 19:34:29
If the leak is up by the radiater, look at the oil lines. My 3010 had a small oil leak in the return line that made a mess in that area. The line was rubbing against metal where it goes down under.
randalp
07-10-2006 22:21:49
having the same type of leak on my 3010. I"ll wash it off, check it out and get back to you in a few..
