420 c
Rick Smith
07-10-2006 19:12:09
a couple of years ago my father and I acquired a 420c dozer in pretty good condition, after having the head rebuilt we got it running but it will not move. After talking to several people they say there is a shear pin some where that might be broke. Any information will helpful.
BillyC.
07-11-2006 10:27:42
 Re: 420 c in reply to Rick Smith, 07-10-2006 19:12:09
If it doesn't have reverser--my '56 420C doesn't-- I would suspect the propeller shaft splines are stripped. It was stripped when I bought it and haven't gotten around to replacing it yet--too hot here in Miss. to work outside in sun. That's the exact symptoms that mine has.
FDBYRD
07-11-2006 10:20:36
RICK, SOUNDS LIKE THE CLUCH PACKS IN YOUR REVERSER ARE OUT. THEY ARE IN THE TORQUE TUBE, BEHIND THE CLUCH & IN FRONT OF THE TRANS. I HAVE HAD A LOT OF PROBLEMS WITH MINE IN MY 1957 420-C.
NORMAN.
CH
07-11-2006 03:55:06
I have parts for that machine, manual also email me
CPeter
07-10-2006 20:11:41
There are no shear pins. There is a coupling at the rear of the drive shaft that can be problematic. Do you have to push the clutch in to put it in gear? That is, is there power as far as the transmission?
More information would help.
CPeter
Rick Smith
07-11-2006 07:11:29
 Re: 420 c in reply to CPeter, 07-10-2006 20:11:41
yes there is power to the transmission when you put it in gear and let the clutch out you can hear a noise and feel a slight vibration
