Things to look for on a 60
Wind
07-10-2006 09:39:55
May soon have the opportunity to look at a 60 that is for sale. Don't want to talk about the asking price yet, but reasonable in my opinion.
What do I definitely need to look at on one of these, other than the obvious stuff. Any particular weak points in the frame or castings I need to be aware of? Any particular tranny problems they were prone to that I shuold listen for? Will be looking at the tractor for work first and restorability second. Need it to run the auger wagon and mower first.
TIA Wind
billde
07-11-2006 05:32:09
 Re: Things to look for on a 60 in reply to Wind, 07-10-2006 09:39:55
If it has live pto, there will be a lever pointing forward at the base of the seat on the right hand side. Unless it has serious problems it's a steal at that price.
Wind
07-11-2006 04:46:40
 Found out a little more in reply to Wind, 07-10-2006 09:39:55
Appears to be pretty much a plain John. No power steering or 3 point. The owner is not sure of live PTO or not. He has only had the tractor a year, but bought it from the original owners widow. The current owner is a younger guy who thought he would like to restore it, but has ran out of time and money (could be good for me). He wasn't sure about the roll-a-matic either. He did say that it starts and seems to run good, he has used to pull some stuff around his horse farm.
Going to take a look one evening later this week.
I am looking at it for work for the first couple of years. Need to pull an auger wagon to fill feed bunk for calves, do some mowing with a pull type gyro mower, and do a little plowing a tillage work to keep it healthy.
Taking to advice of many here, I'll make out a check list and go over it pretty well. Then formulate an offer based on that. Oh yeah, he is asking for about $1250. Can I go worng at that price?
P Browning
07-10-2006 17:34:54
Wind -- take a short stroll to the JD-H Restoration Site, and once there click on the Buyer's Guide. While structured for a Model H, the tone of the piece should help along with pointers from others on this thread to the point where you can make up a checklist! (PatB)
Jak
07-10-2006 14:17:59
Check for exessive noise in the clutch area the drive gear was bad about walking out on the clutch wheel.Also drive some in third and see how noisy it is.It would be nice if you could load it in first gear to see if it is a gear jumper or not.Good luck.
Blksmok
07-10-2006 10:23:48
Wind..... .loose clutch drivers and worn crankshaft splines. Cracked blocks from over torqueing causing cracking around studs. Also check for cracks in flywheel.
Mike M
07-10-2006 11:09:18
 Re: Things to look for on a 60 in reply to Blksmok, 07-10-2006 10:23:48
A big second on that stuff !!
In addition check the flat surface of the bottom of the block for cracks or past welds. Look at the bottom of the cyl. head too while under there.
Walt in Jaxn Tn.
07-10-2006 21:03:49
 Re: Things to look for on a 60 in reply to Mike M, 07-10-2006 11:09:18
Will you be needing live p.t.o.?
Some came with live p.t.o. some didn't. Does it have factory power steering, aftermarket power steering (Char Lynn)or no power steering at all. Does it have a rollamatic front end, if so then check there for wear. Look at the draw bar. Does it have excessive wear or repairs. Cracks in the frame will occur near the front end at the steering pedestal more likely with power steering and especially if the tractor spent most of it's life with a corn picker mounted on it. The engine main bearings are one piece and there is no adjustment for wear, only replacement. Grab the clutch pulley(engaged) and lift to see if you notice any play/movement. That's all I remember for now. --Walt--
