Glen in TX carb plug
Bob
07-10-2006 05:55:52
Glen,
Do you have a source for the brass screw plug for the bottom of the float bowl on an MS carb from an LUC? The old MS part # is 15-409, and Deere also used this as the PN, but it has been discontinued.
Bob
07-10-2006 20:21:02
 Re: Glen in TX carb plug in reply to Bob, 07-10-2006 05:55:52
Thanks, guys!
Duane Larson`
07-10-2006 11:34:35
Hi Glen,
The 15-409 corresponds to a Zenith C138-102, and lists for $10.30 so it is still available. It is just an 8-32 plug that goes in the bottom of the bowl, lined up with the nozzle.
I just turn down a piece of 3/16 brass rod, cut a screw slot with a hacksaw, thread the end, and cut to length.
Or, you could fill the hole on one of the TSX jets for an 8N carb with JBWeld - several of those are 8-32.
Glen in TX
07-10-2006 14:11:05
 Re: Glen in TX carb plug in reply to Duane Larson`, 07-10-2006 11:34:35
Well Bob there it is. I bet you can make one. Thanks Duane! I was thinking of the larger drain plug anyway. Where can I can a guy get M/S to Zenith cross chart anyway?? I've picked on the Zenith people for one those of before with no luck yet.
Glen in TX
07-10-2006 10:14:40
Bob, I don't have any way to cross that number to new Zenith numbers in price sheet. Probably too expensive to order just a plug anyway. You are just needing a hex head brass plug probably and not a needle seat assembly for it? Some plugs were steel or aluminum and I may have some used ones around. Is it a TSX-356 ?
