Dubuque
rurlndum
07-09-2006 18:57:34
Can someone tell me what a "Dubuque" tractor is? Are they different from a "Waterloo" tractor?
Thanks in advance.
jd b puller
07-10-2006 07:37:38
 Re: Dubuque in reply to rurlndum, 07-09-2006 18:57:34
At risk of offending a Dubuque tractor collector.
The Waterloo tractors sound like typical 2 cylinders. pa-pow-pa-pa-pow
The Dubuque tractors sound like big lawn mowers. ppppp ppppp pp
CPeter
07-10-2006 07:49:11
 Re: Dubuque in reply to jd b puller, 07-10-2006 07:37:38
I would have to disagree on the sound. Both Waterloo and Dubuque tractors have the same 180/540 firing and while the sound is different, unless it is a 435 or a 440D they have the same syncopated sound as the Waterloo engines. They are smaller and turn faster, but that is the only difference. The 435 and 440D used a 2-53 Detroit Diesel engine that is 2 stroke and fires every time around and to quote JR Hobbs, sounds like a chainsaw on steroids.
Different models of Waterloo tractors sound different. The "D" is much different than an "H" because of the difference in size and the manifold geometry.
CPeter
buickanddeere
07-10-2006 17:41:02
 Re: Dubuque in reply to CPeter, 07-10-2006 07:49:11
Any gas Dubuque has an unique "dutt, dutt, dutt" soaund at idle or light loads. Changes to a "bark/putt, bark/putt" when at full power. The B,50,520/530 had a sound of thier own too. I tried the 435 without a muffler or stack while blowing snow. Sounded like a Continental in a Massey 44.
jd51mt
07-10-2006 07:10:18
The Model "L" was built at the Wagon Works factory, Moline, IL. The proto types and the first production Model "M" was also made there in March 1947. The production of the Model "M" was then transferred to the Dubuque factory, Dubuque, IA after the factory was completed.
leon
07-10-2006 04:44:38
Dubuque actually stared with the model M, then added the MT and MC ahead of the models Bubba lists. As long as the Dubuque tractor model has just three digits, they have vertical, two cylinder engines with foot clutch. All have hydraulics. In power, they are smaller than the Waterloo tractors built at the same time.
Mike M
07-10-2006 06:45:43
 Re: Dubuque in reply to leon, 07-10-2006 04:44:38
I thought it started with the model 62 then the L and then the LA and then the M ?
bubba 2
07-09-2006 19:28:20
Location of where is was manufactured and a whole lot of differences in the engineering departments of each plant.Dubuque built the small tractors(or tried to at least)like the 40-420-430-1010-,and 2010.Waterloo built models like the 50- 60-70--80--520-620-720--820-530-630-730-830-3010-4010-5010-3020-4020-5020-etc.
