Float ride seat on a 730 Diesel
Adam in IA
07-09-2006 10:05:39
I need to know the procedure for the unassembly and reassembly(with new parts) on the seat frame. I have it removed off the tractor and the shock absorber is off that is as far as i have gotten. Basically i need to know how the little shafts that hold everything together come out, and how the torsion springs come out and so on. Any help is much appreciated. Thanks
Brent in WI
07-09-2006 19:20:59
 Re: Float ride seat on a 730 Diesel in reply to Adam in IA, 07-09-2006 10:05:39
See a recent post in JohnnyPopper.com about the same topic with a few extra hints and info.
Brent
http://www.johnnypopper.com/forums/index.php?act=ST&f=1&t=12064&s=2bcb849898fff1dad2d11ab663c65ff7
Mike M
07-09-2006 11:56:23
The springs have roll pins holding the adjuster and the rear cover together drive them out and pry it apart. The pivot shafts at each corner have knurled spots in the center that hold them into the metal part. An air hammer works great to knock those out. I use a C clamp to press them back in when assembling.
mjbrown
07-09-2006 11:04:55
Adam;
Those seats are a puzzle. In the John Deere service manual it covers four pages and ten illustrations! I did it six or seven years ago and it involve a lot of prying, penetrating oil and bad language.
The rear bulkhead comes off first then the cross arms on the springs then the shock then the front pins are driven toward the inside of the frame. If you are mechanicaly inclined you can figure it out. The best way it to get a JD Service manual!
Adam in IA
07-09-2006 14:35:33
 Re: Float ride seat on a 730 Diesel in reply to mjbrown, 07-09-2006 11:04:55
I got it apart. Thanks for the advice. Now the challenge will be remembering how it goes back together!
Bob
07-09-2006 14:42:48
 Re: Float ride seat on a 730 Diesel in reply to Adam in IA, 07-09-2006 14:35:33
Did you snap a couple of pictures before pulling it apart?
Bob
07-09-2006 14:55:25
 Re: Float ride seat on a 730 Diesel in reply to Bob, 07-09-2006 14:42:48
P.S.,
Where's a good place to get new rubber torsion springs for the seats?
mjbrown
07-09-2006 16:13:48
 Re: Float ride seat on a 730 Diesel in reply to Bob, 07-09-2006 14:55:25
I think I got mine at Minn-kota but it's been a while. I spray them with silcone at least once a year to try to prevent them from checkering and deteriorating. It's not a job I want to do again soon.
Adam in IA
07-10-2006 05:08:45
 Re: Float ride seat on a 730 Diesel in reply to mjbrown, 07-09-2006 16:13:48
No i didnt take pictures but i have the assembly loosely laying together in order. I got my springs off ebay, i guess we will see how they work.
