How to get a taperlock flywheel off
chrisfromsolitude
07-08-2006 18:43:09
Working on a 70 gas and it has a taperlock flyhweel on it. First question is how to get the flywheel off the hub thats pressed on the crank? Does the flywheel come off the hub or does the hub come off the crankshaft? I have tried everything and can't get this thing to budge. Thanks for any help.
mjbrown
07-09-2006 16:21:33
 Re: How to get a taperlock flywheel off in reply to chrisfromsolitude, 07-08-2006 18:43:09
I put a thin coat of grease on the cone and the inside of the flywheel so it would go on tight and really squeeze the crank and so I could get it off again someday. Now I've recently had it loosen up so take it with a grain of salt. I did not put any grease on the crank splines or the splines on the cone and that is where it slid.
Hilltopper
07-08-2006 19:28:51
I can answer that the flywheel comes off the hub.I recently installed one on my 720d the instructions said to loosen the large nut and hit the crank shaft with a sledge hammer. You are supposed to leave the nut on to keep the flywheel from from flying off the shaft. I can tell you there is no danger it will not come off. I think I will need to build a heavy puller that can put pressure on the shaft as you hit on it.
jddriver
07-08-2006 19:27:26
My taper lock comes off the taper and then you take the wedge off off the flywheel.We take a large (read VERY big )pry bar in at least two places and pry out on the flywheel while taking an oak block and holding against the loosened nut and hitting it very hard with a large sledge.BE PAITENT.Steve
Mike M
07-08-2006 20:03:41
 Re: How to get a taperlock flywheel off in reply to jddriver, 07-08-2006 19:27:26
That's the way I get them off too. A helper is almost a must.
