G clutch brake bushing replacement
Gwiz
07-08-2006 13:08:57
Can I replace the clutch brake bushing without tearing the whole tractor apart? If I remove the cover on front of the belt pulley housing, can I remove the clutch brake shaft and replace the bushing? Or will removing that cover cause other things to come apart that I don't really want to get into?
Thanks
James
Mike M
07-08-2006 14:42:50
 Re: G clutch brake bushing replacement in reply to Gwiz, 07-08-2006 13:08:57
You can just unbolt that 4 bolt casting and pull it out. But those don't have bushings in them from the factory and once worn you will need to get someone with a machine shop to make you some.
