30 series and mowers
sodly
07-08-2006 11:59:17
Can anyone give me approximate sizes (widths) of bush hog style mowers that work well with 530, 630, 730 tractors? Will a 530, for instance, handle a 6' mower? 8' mower? Also, how fast is reverse in these tractors? Is it hard to mow because reverse is too fast?
johns48b
07-08-2006 17:42:12
 Re: 30 series and mowers in reply to sodly, 07-08-2006 11:59:17
if your going to do that much backing up, i'd be trading for a tractor with a foot clutch. a frail mower is meant more as a finishing mower. it will cut just about anything small in diameter, but the blades on it are a pain to change if they get dull. i made a grinder just to sharpen the blades on one of those frail mowers. its has to do with a grind stone with a metal backing plate, geared down real slow and a vise that will clamp the blade in it and move in and out as well as side ways. i keep the stone wet with a spray bottle and don't feed the blade in to fast. the mower doesn't work real well with tall grass, especially if its real thick.
Mike M
07-08-2006 14:46:06
I had a 7 1/2 foot flail mower on a 530 and it worked real good. I have ran 5 foot brush hogs on a model B and mowed grass as high as the hood so a 530 should handle one much larger at least as wide as the wheels.
sodly
07-08-2006 14:53:41
 Re: 30 series and mowers in reply to Mike M, 07-08-2006 14:46:06
That's an intereting point. I've never used a flail mower, but they look like they make more sense than a Bush Hog style mower. Do you just adjust the cutting height with the 3 point? I think they use shoes for low cutting, right? Do you happen to have any pics of that setup that you could share with me? I'm mowing prairie grass (and weeds for now) so I need to eventually be able to set the mower up to mow up to maybe 1 foot tall cutting height. Would a flail mower do this? Seems like it would be much more maneuverable than a Bush Hog, too. Thanks.
Mike M
07-08-2006 20:32:47
 Re: 30 series and mowers in reply to sodly, 07-08-2006 14:53:41
There is alot of misinformation on these forums about flail mowers. Right out of the Land Pride product guide. They have 3 different styles. FM20 1" cutting capacity 0-4" cutting height. FM30 1" cutting capacity 1/2" to 6" height and FM40 2" cutting capacity with 1/2" to 6" height. You adjust the top link for the front height and you can adjust the full length roller at the rear where needed to get your cutting height. I have always bought used Ford models you can get them pretty cheap New ones are REAL expensive. Just check and make sure no one bent the rotor. I really like these because they are far safer than bush hog types when you hit an object,mow much better cut and pick up the wheel tracks. They do need more HP than a bush hog and the heavier the stuff the more it takes. If you get into real high grass with too small of HP the rotor speed drops and then the grass will wrap,keep the speed up and no problem.I never really had any issues with sharpening. My first mower I just put all new Heavy Duty blades on it and never had to mess with them. The last one I bought I just pulled them all off and sharpened them on a grinding wheel(time consuming) Not bad at all to remove. rotate a lock plate grab ahold of the rods 3 total and pull them out all the knifes and holders will drop on the floor. To install just start the rod in and then put each knife up into the hole slide rod in more and repaet until done. This is on the Ford models some others may be harder to do.
If you really want to cut heavy stuff fast get a disk mower. They have easy to replace blades,but will really throw rocks ! They could cause a real disaster if you hit something. They don't chew it up just lay it down like a sickle bar.
CLW
07-08-2006 12:59:59
Sodly, I don't know what reverse speed has to do with a bush hog but the 530 is 2.5 mph, 630 is 3.0 and 730 is 3.25. Since I don't have a brush hog on my 630 I will yield to those that use them as to what size for each tractor.
sodly
07-08-2006 14:49:24
 Re: 30 series and mowers in reply to CLW, 07-08-2006 12:59:59
I'm mostly just wondering if reverse corresponds with a good (forward) mowing gear. That is, if you have to back up and mow a stretch, will you have to change RPMs to compensate for a tall reverse gear or will you be going roughly the same speed. In the tractor I have now 2nd gear (mowing gear) is almost exactly the same speed as reverse. It works out so well I can mow back and forth without turning the tractor around at the end of a row. Just do one pass forward and the next backwards. Also, I hope to move a little snow which might be a lot of reverse work. Thanks.
