3020 power steering leaking
Illinois Farmal
07-07-2006 19:52:29
If I wasn"t having enough problems with my 3020 missing badly, I think I also blew a seal out of the power steering. Is there a seal that "routinely" goes out on these units? How difficult is it to replace? I haven"t pulled the shield off yet to get a closer look but there is plenty of oil/fluid dripping out from under the front end. This is my 1st green machine that I"ve owned and I"m already having fits. Please tell me it gets better!
Glen in TX
07-08-2006 12:09:48
 Re: 3020 power steering leaking in reply to Illinois Farmall, 07-07-2006 19:52:29
You can view parts book for your 3020 at JD parts online by clicking on "parts catalog" in left column and then entering 3020. Those plastic return lines from the seal area of pump are famous for leaking.
Tx Jim
07-08-2006 04:02:14
The main hyd. pump could be the problem or it could be as simple as the pump seal plastic drain line leaking. Tx Jim
