3020 missing bad/power loss
Illinois Farmal
07-07-2006 18:38:14
I just traded for a 1966 3020 gas a few weeks ago and put it to the test this afternoon baling hay. I knew something was amiss as I was going down the road and was having trouble keeping it from stalling. When I got in the field and started baling I had to treat the throttle gently in order to keep it running. I managed to get the baling finished but I could tell the engine wasn't running right. It acted like it was starving for fuel. I got it home, barely, and by then it was missing badly, sputtering and popping. At times I had to have the choke out in order to keep it running. I checked the fuel flow and filter and everything seemed fine there. Where should I go next??? Thanks.
mattoney
07-07-2006 20:49:37
 Re: 3020 missing bad/power loss in reply to Illinois Farmall, 07-07-2006 18:38:14
When I have to hold out the choke on my Ferguson, it means the carb is plugged up with just a little bit of junk that got past the filters. So I"d take it off and carefully dissassemble it, remove the valves and blow out every orifice you can find with either compressed air or a good quality carb cleaner. Dad likes to run a small piece of wire through the orifices too to make sure they"re clean but I"m not exactly keen on this idea even if it does work.
Also, you probably already know this but be sure to pay attention to how far the needles are adjusted out from the carb so you know where to set em when you put em back in, or have a good manual handy. Then put er back together and slap it back on the tractor and that usually does the trick til the next time it plugs up!
Gerald J.
07-07-2006 20:24:59
Lift pump. I put an electric pump on my gas 4020 to keep it from leaking gas into the crankcase the next time it dies.
Intake manifold gasket letting in air.
Then it could be ignition, something like worn distributor bushings to not have consistent timing. Resistance wires, I had some that went open with engine vibration? Resistor plugs? Wrong plug gap, bad condenser? Timing?
Have you a manual? How warm is it where you are? My 4020 wants carburetor heat up to 90 unless its plowing, then it wants that heat off at 70. Because part of the intake manifold heat jacket is broken, I can't put heat on an it sure shows that need for heat when I try E10 in it.
Gerald J.
bill mar
07-07-2006 19:08:35
if you had to pull the choke to keep it running dont know if the new generation carbs have the same problems as the two cylinders but, the older tractors are known for have having plugged passages, just a thought. bill m.
Hayfarmer
07-07-2006 18:57:13
If fuel flow is good from filter, I would check ignition next. Points, condensor, plugs, cap, wire and rotors. Check advance in distributor also. Could also be leaky intake manifold gasket or lack of compression. Start with the easy stuff and work up.
