JD 50 -wico distributor
Pinkroses
07-07-2006 11:52:21
I have JD 50 12volt negative. want to change over from wico xb distributor to Delco. Which one do I need? How difficult is it to change? I really want to change to electronic ignition. Can anyone help?
Thanks in advance. Debbie
John T
07-07-2006 12:25:22
 Re: JD 50 -wico distributor in reply to Pinkroses, 07-07-2006 11:52:21
Debbie, I agree with my Mentors and changing out the Wico to a Delco is a smart move far as Im concerned. For one thing, the Pertronix Electronic Ignition switch will fit easiy right into that Delco to replace the points and condensor (bolts right in, its a piece of cake I bet even my first wife could handle it lol) and I HIGHLY recommend you couple it up to one of the high energy Flame Thrower coils Pertronix also sells to match the switch. Just be sure n match the electronic switch to whatever ground youre at, the factory original Positive or if you convert over to negative. Timings NOT rocket science either its easy to figure out.
John T
Duane Larson
07-07-2006 12:12:39
Debbie,
You will need a Delco Remy 1111558 distributor, and a 12V coil. You might check eBay for the distributor, or if all else fails check back with me. The coil can likely be purchased along with the electronic ignition, or check Tractor Parts on the top left of this page. They are not hard to install - should be lots of advice available here if you get stuck.
Glen in TX
07-07-2006 12:03:50
Get the Delco and Pertronix electronic ignition for 12V neg. ground if that's what you want. You can get the kits for positive ground also. No electronic kits available for the Wico dist. and they don't work well on 12V anyway because they were originally designed for 6V.
