720 leak
pwd
07-07-2006 04:15:32
got a 720 diesel that started leaking somewhere around the flywheel. i replaced the crank seal (old one looked good) still leaks just as bad. it only leaks when running.it is a big drip almost a steady stream. any ideas? thanks for any advice. paul
Blksmok
07-07-2006 07:22:31
 Re: 720 leak in reply to pwd , 07-07-2006 04:15:32
PWD....did you make sure you centered the thrust cover when you replaced the internal seal in the spacer? If it's centered and you have new seal, excessive wear on the main bearings will cause leakage due to the seal's inability to follow the elliptical path of the crankshaft as it turns.
