Rusty Flywheel......Rust Remover?
NortexJD
07-06-2006 05:31:17
Got this old rusty flywheel from a salvage yard. I want to clean it up and put it on my A. It will have a cover over it, but would still like to knock off the rust and paint it with JD paint from a spray can.
Can anyone recommend a good spray on rust remover that can be followed up with primer and paint? I don't want to be sanding much on this big hunk of cast iron. My knowledge of painting is very limited. Any help is appreciated.
zwr
07-07-2006 19:30:12
 Re: Rusty Flywheel......Rust Remover? in reply to NortexJD, 07-06-2006 05:31:17
Frank: I always enjoy reading your responses. And it does sound as if you're a chemist. I worked for a time at an anodizing shop, and once was unloading a tankwagon of 80% phosphoric. There was a drip at the hose connection and I put a common, metal (steel ?), 5-gal pail to catch it, thinking it would be OK because phos is a "weak" acid. When I went to clean up, I lifted the pail and its bottom (and about a gallon of acid) came right out of it. Did the phos eat the steel or perhaps eat the soldering material at the seam?
F-I-T
07-07-2006 20:15:13
 Re: Rusty Flywheel......Rust Remover? in reply to zwr, 07-07-2006 19:30:12
Hard to say, but keep in mind that most inductries don't want to buy their acid products pre-diluted, so they buy the acid in its most concentrated form without the extra water. The industrial grades of any acid, when held in concentrated form, will react quite differently as that purchased in the significantly lower molar strengths offered to the consumer. Phosphoric Acid at 85% is 15 M and Hydrochloric Acid is 12 M at only 37%, so the Phosphoric Acid you were dealing was quite strong, but would be difficult to buy in a poly jug at Home Depot. One product that I use lists that it is 33% by wt. 85% H3PO4, and which is then to be diluted 4 to 1 with water, so if it was 12 M concentrated, then it is in a container that is dilluted to a third, then it is 4 M, and then 4 to 1 leaves it as 1 M at the point of use. Then you are putting it on a flat panel, exposing it to the atmosphere so that it can out gas and dry quickly, so there is not a lot of damamge it can do in the time it takes to dry as compared to the concentrated state in a bucket where the surface could layer its off gasses and shield it form blow off by the air. Lots of reasons that in your circumstance you melted the bottom of the bucket, including a galvanized seal, and stronger acid than you would normally be asked to handle as a comsumer.
Phosphoric Acid is added to most soft drinks to give the tang that bites your tongue, and most people think that that is why Coca-Cola is acidic. The truth is the CO2 gas used for the carbonation is the most acidic component in it. CO2 gas is highly acidic though most pepople are not aware of that.
Frank
P Browning
07-07-2006 10:01:50
NortexJD -- Of all the solutions you have to choose from, I ask that you concentrate on protecting the splines of the replacement flywheel. Being used, there will already be some spline wear; your crank won't be perfect anymore either, and surely you must do all you can to have a nice snug & lasting clamp of the flywheel onto the crank in the final analysis -- rust on the wheel be damned. Therefore, I would avoid any compound or process that would tend to erode steel from the splines, and also avoid any compounds that would leave behind a build-up on those splines. If spraying or brushing rust-converting compounds onto the flywheel at some point in the process, you can mask off the splined region. As for getting the splines cleaned, elbow grease and wire brushing shouldn't be ruled out! An Observation! Let's keep this simple. (PatB).
CalJim
07-06-2006 23:12:31
NortexJD,
Just a reminder to carefully check that salvaged
flywheel for cracks. Look for hairline cracks in
the area where it bolts to the crank. A flywheel
with any cracks should never be used. They have
been known to come apart at full speed, you can
imagine the potential for disaster. Also keep in mind that those flywheels and crank-
shafts were balanced together as a unit at the
factory. But as long as the splines are not worn
and match up well the flywheel should tighten up
fine. You should know right away if there is any
vibration when you start it up. Just my 2.5 cents CalJim
NortexJD
07-07-2006 06:16:20
 Re: Rusty Flywheel......Rust Remover? in reply to CalJim, 07-06-2006 23:12:31
CalJim, thanks for the info. I took off the original flywheel to replace the crank seal. I noticed that the ring gear was chewed up pretty badly, and after closer examination I noticed a hairline crack on the face and going down the side of one bolt hole. I bought another flywheel off e-bay for $50.00 and the splines look good and I did not see any cracks in it anywhere. I'm going to clean it up and give it a try. Will inspect it much closer after I get all the rust off. Believe it or not the parts guy at the JD dealer here in north Texas said the new flywheel was still available at $1,100.00!! Needless to say I started looking on e-bay and elsewhere. Hoping this one works.
Marty Z
07-06-2006 07:53:03
Go with the P Browning Idea. A small wire wheel on the drill , then a spray can of gray primer. Then paint it with john deere green from tractor supply or JD dealer. Even a pint of brush on paint for this job would be good. Might cover better too. Some day you will have all the tools to clean this up 5 different ways.
Marty Z
P Browning
07-06-2006 06:30:27
How about a wire brush?? Perhaps even a wire brush on the end of a portable drill or side grinder! Follow it up with some OSPHO to convert remaining rust, then shoot with a can of JD Green from your local hardware or tractor supply store. And if you don't have OSPHO or don't want to buy a quart of it, fetch some EXTEND or RUST CONVERTER -- both trademark names - in aerosol cans; and one or the other available at your local Big-Box store! All simple things. (PatB)
chile2
07-06-2006 10:09:43
 Re: Rusty Flywheel......Rust Remover? in reply to P Browning, 07-06-2006 06:30:27
try using some oven cleaner
Alabama Dogwood
07-06-2006 06:01:17
Maybe this ..... Link
Kurt_JDB
07-06-2006 05:46:00
Best rust remover/converter is FIT"s electrolysis Bath. Get a big plastic tub, fill it with water and lye to the proportion of one gallon of water to i tablespoon of lye,Put the flywheel in the tub. Get a battery charger, and hook the black lead to the flywheel and hook the red lead to a piece of scrap. Don"t let the flywheel touch the scrap.
FIT has a very good write up on his web site. Sorry, I don"t know the address. Suggest you confirm the polarity, as I may be remembering it wrong.
Anyway it does a bang up job of converting rust, in preparation for paint
Kurt
F-I-T
07-06-2006 08:47:18
 Re: Rusty Flywheel......Rust Remover? in reply to Kurt_JDB, 07-06-2006 05:46:00
Eectrolysis articlte is at www.fboerger.com. I personally would use an electrolysis bath, but if you don't have one set up, slop it with lye gravy to remove the old grease, oil and paint, then rinse, then Phosphoric Acid spritz, scrub that around with a stiff wire brush, rinse, and if red rust is still present, do the phosphoric acid thing again until it's either clean or the red rust has been converted to black oxide. CLean it well down within the spines.
I have an article on the lye gravy process showing photos of the cleaning of a F1500 rear cast center and it's about the same trouble to clean as a flywheel. Did it during an afternoon watching football most of the itme.
Frank
NortexJD
07-06-2006 12:07:24
 Re: Rusty Flywheel......Rust Remover? in reply to F-I-T, 07-06-2006 08:47:18
Thanks guys for all the good advice. And thanks FIT for the link. You guys have been a big help in fixing this old A up. Thanks again.
Skyhawk Greg
07-07-2006 07:43:42
 Re: Rusty Flywheel......Rust Remover? in reply to NortexJD, 07-06-2006 12:07:24
NJD - Muriatic acid can be purchased very cheaply in gallons at many hardware stores. If you pour some acid into a plastic tub, and then immerse the flywheel in it for 10 or 15 minutes, it will come out looking brand new (quite literally). If there is rust on the splines, it will eat it away, so you may want to put it into the bath sideways to keep acid off the splines. The acid will create its own exothermic reaction which will make the solution hot, and it will start to off gas. This is OK. The only reason it is happening is because it is having a chemical reaction with the rust. I have tried almost every other method imaginable, and the acid, as simple as it is, seems to work the best and takes the least amount of time and effort.
F-I-T
07-07-2006 08:30:04
 Re: Rusty Flywheel......Rust Remover? in reply to Skyhawk Greg, 07-07-2006 07:43:42
Greg:
Muriatic Acid, which is the trade name for Hydochloric Acid will dissolve the steel or cast iron which is why the rust appears to leave. You've eroded the base metal the rust was attached to. If you use HCl on close fitting mating parts you'll end up with a looser fit after the "cleaning". Better to use H3PO4, Phosphoric Acid which is so mild that it dosn't touch the steel/iron, AND it chemcically converts the red rust (Fe2O3) into the inert black oxide (Fe3O4), so the back stuff will not rust again even uncer primer or paint.
That's what puts the etch in etching primers. Gives a tooth without removing metal.
Frank
Skyhawk Greg
07-07-2006 10:58:56
 Re: Rusty Flywheel......Rust Remover? in reply to F-I-T, 07-07-2006 08:30:04
Hello Frank,
To expand a bit on what you said, there are two reactions when any acid touches a rusted metal part. The first simple exchange reaction is the one with the rust, and the second oxidation reduction reaction is the one with the base metal. Using phosphoric acid, the first reaction, on the rust, is Fe2O3+2H3PO4 -> 2FePO4+3H2O. This takes place rather quickly. The second reaction, on the base metal, is Fe+H3PO4 -> FePO4+H2. This is not nearly as fast. If you use muriatic acid (diluted HCl approx. 30% by weight), the two reactions are chemically the same when you substitute the Cl in place of the PO4. The big difference is in that BOTH of the reaction rates of the HCl are at a rather fast pace (eating metal almost as fast as rust). So, yes, I agree with you that using a strong acid, such as muriatic acid, on a dimensionally critical part could cause more damage than a weak acid on the same part. The reason that I like to use muriatic anyway, is that I keep an eye on the parts and pull them out the instant they are ready to be removed. I am not a patient person by nature, and am not convinced that there really is that much difference if you pull the part out on time. You got me though, in that the FeCl3 does not stick to, and protect the metal surface like the FePO4.
I know, or at least think I know, that you are either a chemical engineer, or a chemist. I am not, nor even close, so I am interested in your electrolysis method. Is it superior to chemical reactions in that it does not dissolve, but rather, it works by forming gasses underneath the corroded areas which causes the rust to flake off, which would leave the base material intact?
I hope this made sense, as people have been interrupting me incessantly since I started writing.
Greg
F-I-T
07-07-2006 14:44:56
 Re: Rusty Flywheel......Rust Remover? in reply to Skyhawk Greg, 07-07-2006 10:58:56
First off, check the valence of HCL versus Phosphoric Acid. HCl is just much stronger than Phosphoric Acid, and that is the reason that the two cannot be compared as equals in the removal of metal abd the subsequent conversion to a metal salt. For the same reason, vinegar (Acetic Acid) is an acid, but not nearly as strong as HCl, Nitric, or then on down to Phosphoric. Muriatic Acid is best left to cleaning masonry and toilets. But use what you want, but patience is a virtue, and eroded splines are not.
~~...Is it superior to chemical reactions in that it does not dissolve, but rather, it works by forming gasses underneath the corroded areas which causes the rust to flake off, which would leave the base material intact?
The reaction is both electrochemical and mechanical. It does indeed have the mechanical effect of lifting old finishes because the hydrogen bubbles will lift the edge of the old finish and the paint will lose its mechanical bond. Additionally, the red rust is converted from Fe2O3 to Fe3O4 (black oxide) during the same reaction as iron metal from the sacrificial electrode is added to the red rust, turning it black, at which point the electrode will turn red with red rust. The black oxide will not longer rust as it is full of electrons and isn't interested in combining with anything else. All you need is a simple electrolyte like lye (NaOH which is helpful in emulsifying grease oil as well) or sodium Carbonate (Washing Soda found at the grocery laundry aisle) and a low voltage DC power supply. I use a 5 volt computer rack supply that can provide up to 400 amps, but I seldom run it over 50 A or so. It is the best cleaning method I have found.
As an aside to the use of Phosphoric Acid, it leaves behind a thin phosphate coating which will serve as a rust inhibitor. I spray my cleaned parts with Phosphoric Acid and let it dry and if I'm not going to paint them for a while, they can be stored for weeks and they will not rust. When you're ready to paint, scuff the loose white flash crystals off and prime right over them. If you use HCl, the metal should be to be neutralized immediately with a suitable base, then washed, and then oiled, or the Chlorine salts left behind will react as if you placed the piece in a salt water bath. Since the Chlorine salts are so hydrophylic, they will draw and react with moisture drawn from the water vapor.
Hope this helps.
Frank
NortexJD
07-07-2006 08:57:34
F-I-T, good info. Do the spray cans of Extend or rust converter also convert the red rust to black oxide where it will not rust again under paint? Are there any of these type products that you would recommend? Do they take the place of primer?
F-I-T
07-07-2006 10:55:53
 Re: Rusty Flywheel......Rust Remover? in reply to NortexJD, 07-07-2006 08:57:34
third party image
My "favorite" is Ph-Ospho-Ric+ because I can buy it at my local Lowe's or Home Depot. I think most of your answers asre covered in the information on the label.
~~Do the spray cans of Extend or rust converter also convert the red rust to black oxide where it will not rust again under paint?
Can't say as I have never used Extend, but odds are really good that all of them are basicalyl H3PO4 un a spray can. I find it cheaper to sue a hand squirt bollte.
~~Are there any of these type products that you would recommend?
Phosphoric+
~~Do they take the place of primer?
No. Let it dry, scuff with some brown Scotchbrite or 240 grit sand paper, wipe off the dust and then spray or brush prime.
Frank
